6584 Discussions
OpenVINO Opencv and the raspian-stretch installation
Lawton__John
Hi
I continue installing OpenVINO as per:
https://software.intel.com/en-us/articles/OpenVINO-Install-RaspberryPI
In the section: 'Run Face Detection Model Using OpenCV* API'
I am attempting to execute the python3 script
openvino_fd_myriad.py.
This fails as 'import cv2 as cv' fails to find the cv2 modue.
Please can anyone advise which is the correct location of the Opencv distribution
and what should be installed in addition eg numpy.
Thanks in advance for your help
                                     John
Hyodo__Katsuya
Innovator
What is the result of the following command? $ printenv | grep cv
Lawton__John
Hi Hyodo
The result is:
LD_LIBRARY_PATH=/home/pi/Downloads/inference_engine_vpu_arm//opencv/lib:/opt/intel/opencl:
/home/pi/Downloads/inference_engine_vpu_arm//deployment_tools/inference_engine/external/hddl/lib:
/home/pi/Downloads/inference_engine_vpu_arm//deployment_tools/inference_engine/external/gna/lib:
/home/pi/Downloads/inference_engine_vpu_arm//deployment_tools/inference_engine/external/mkltiny_lnx/lib:
/home/pi/Downloads/inference_engine_vpu_arm//deployment_tools/inference_engine/external/omp/lib:
/home/pi/Downloads/inference_engine_vpu_arm//deployment_tools/inference_engine/lib/raspbian_9/armv7l:
OpenCV_DIR=/home/pi/Downloads/inference_engine_vpu_arm//opencv/cmake
Thank you for your prompt attention.
                         Regards John
