NOT_ALLOCATED
So I have installed the NCS SDK V2 on a ASUS Tinkerboard. We can run the example fine. However I have some problems.
1) I can compile the model but I get the following problem:
linaro@linaro-alip:~/Desktop/ncsdk/api/src$ make
if [ ! -e ./version.txt ] ; then echo "missing version.txt file"; exit 1; fi;
cc -shared obj-armv7l/mvnc_api.o obj-armv7l/fp16.o obj-armv7l//home/linaro/Desktop/ncsdk/api/src/common/components/XLink/pc/usb_boot.o obj-armv7l//home/linaro/Desktop/ncsdk/api/src/common/components/XLink/shared/XLink.o obj-armv7l//home/linaro/Desktop/ncsdk/api/src/common/components/XLink/shared/XLinkDispatcher.o obj-armv7l//home/linaro/Desktop/ncsdk/api/src/common/components/XLinkConsole/pc/XLinkConsole.o obj-armv7l//home/linaro/Desktop/ncsdk/api/src/common/components/XLink/pc/UsbLinkPlatform.o -o obj-armv7l/libmvnc.so.0 -lpthread -lusb-1.0 -ldl -lmvnc_highclass -L/usr/local/lib/
/usr/bin/ld: cannot find -lmvnc_highclass
collect2: error: ld returned 1 exit status
Makefile:50: recipe for target 'obj-armv7l/libmvnc.so.0' failed
make: *** [obj-armv7l/libmvnc.so.0] Error 1
2) So it turns out I don't need to compile the model anyway as on the ncsdk2 branch of the modelzoo the model is included. So I go to run it on the Tinker Board and I get this:
linaro@linaro-alip:~/Desktop/ncappzoo/caffe/SSD_MobileNet$ python3 run.py
Traceback (most recent call last):
File "run.py", line 12, in
import mvnc_simple_api as mvnc
File "../../ncapi2_shim/mvnc_simple_api.py", line 10, in
class mvncStatus(Enum):
File "../../ncapi2_shim/mvnc_simple_api.py", line 23, in mvncStatus
NOT_ALLOCATED = mvncapi2.Status.NOT_ALLOCATED
File "/usr/local/lib/python3.6/dist-packages/mvnc/mvncapi.py", line 46, in _getattr_
return getattr(self.new_target, attr)
File "/usr/lib/python3.6/enum.py", line 324, in _getattr_
raise AttributeError(name) from None
AttributeError: NOT_ALLOCATED
3) I realised that when i cloned the ncsdk into /test and it worked its because it was v1 so i deleted and recloned the repo (to be sure) and switched to v2 and sure enough i cant make the api/src folder. I tried switching back to model zoo v1 and using the graph file i created which was in v1 sdk and it says
File "run.py", line 216, in
sys.exit(main())
File "run.py", line 196, in main
graph = device.AllocateGraph(graph_in_memory)
File "/usr/local/lib/python3.6/dist-packages/mvnc/mvncapi.py", line 203, in AllocateGraph
raise Exception(Status(status))
Exception: mvncStatus.UNSUPPORTED_GRAPH_FILE
Any ideas? As I'm really stumped.
Thank you!
@djaenicke
Hi, did you use mvNCCompile from ncsdk2 to create your graph?
If yes, try to recompile
