6577 Discussions
Not able to convert openvino2021 code to openvino 2022.4 properly.
TarunM
I am able to run this  https://github.com/Megvii-BaseDetection/YOLOX/blob/main/demo/OpenVINO/cpp/yolox_openvino.cpp on OpenVino2021.4 but it is not giving the correct output when I use c++ latest openvino 2022.1
(values are different of output ->latest openvino2022.1)
I am able to run the c++  code to 2022.1 after some modifications but infer output values are different from 2021.4.
I suspect an input or output ; setting or precision problem in my converted code, or maybe a problem when I set the input using method
std::shared_ptr<unsigned char> getData(cv::Mat& img)
or maybe a problem when I get the output as float*
The ir file works perfectly with python openvino2022.1 only problem in using c++.
Please help. Attached is my converted c++ code to 2022.1 OpenVino.
IntelSupport
Community Manager
Hi TarunM,
Thanks for reaching out.
 I am able to run https://github.com/Megvii-BaseDetection/YOLOX/tree/main/demo/OpenVINO demo using the yolox_tiny model for both python and CPP. Also, I am using OpenVINO 2022.1.
Both python and CPP demos give the same output as below.
However, I am unable to run your converted CPP file. Please provide the workaround and related files for us to validate and test on our end.
Aznie
TarunM
Wow! Can you please provide your OpenVino2022.1 c++ code? That will be great healp. I will try that. If that works for me, no need for further investigation.
IntelSupport
Community Manager
Hi TarunM,
Here I share my workaround and also the file that I used.
  1. Download YOLOX-Tiny
  2. Git clone https://github.com/Megvii-BaseDetection/YOLOX.git
  3. Go to YOLOX/demo/OpenVINO/cpp folder.
  4. Run mkdir build
  5. Cd build
  6. Cmake ..
  7. make
  8. Run ./yolox_openvino <model_path/yolox_tiny.xml> <image_path>
Aznie
Hairul_Intel
Hi TarunM,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Hairul
