ONNX conversion - ops missing
Tr__Ra
Hello
I am trying to convert a CNN model from ONNX to OpenVINO.
The following 2 ops are missing:
Instructions/layers that do not have attribute extractors:
[ WARNING ]      Sub (2)
[ WARNING ]          Sub_78
[ WARNING ]          Sub_140
[ WARNING ]      Min (3)
[ WARNING ]          Min_87
[ WARNING ]          Min_88
[ WARNING ]          Min_89
Min and Sub. Can you please provide some guidance as to how/where to add them?
Thank you
Rizal_Intel
Hi Ra Tr,
Sub should be a supported ONNX layer while Min is not.
You can check ONNX supported layers to see a list of supported layers.
There is a section for implement custom layer using the Custom Layers Guide.
However, it seems that ONNX conversion could not support custom layers.
Therefore, I would recommend you to tweak your model to not use the Min layer if possible.
Additionally, here is a list of validated models and topologies that are compatible.
Rizal
Tr__Ra
Rizal_Intel
Hi Ra,
Intel will no longer monitor this thread since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Rizal
