6577 Discussões
OPENVINO-2022 Please contact Model Optimizer developers and forward the following information
efnna
Principiante
2.144 Visualizações
Hey,
I am trying to use MO on a tf 1.4 model,
but i get an error
[ 2022-03-29 11:05:37,251 ] [ DEBUG ] [ infer:168 ] Outputs:
[ 2022-03-29 11:05:37,252 ] [ DEBUG ] [ infer:19 ] output[0]: shape = [1], value = [0]
[ 2022-03-29 11:05:37,272 ] [ DEBUG ] [ infer:343 ] Executed reverse infer for node 'probability'
[ 2022-03-29 11:05:37,274 ] [ DEBUG ] [ infer:347 ] --------------------
[ 2022-03-29 11:05:37,275 ] [ DEBUG ] [ infer:348 ] Reverse infer for probability
[ 2022-03-29 11:05:37,275 ] [ DEBUG ] [ infer:349 ] Op: Identity
[ 2022-03-29 11:05:37,275 ] [ DEBUG ] [ infer:350 ] Outputs:
[ 2022-03-29 11:05:37,275 ] [ DEBUG ] [ infer:19 ] outputs[0]: shape = <UNKNOWN>, value = <UNKNOWN>
[ 2022-03-29 11:05:37,275 ] [ DEBUG ] [ infer:353 ] Inputs:
[ 2022-03-29 11:05:37,275 ] [ DEBUG ] [ infer:19 ] inputs[0]: shape = <UNKNOWN>, value = <UNKNOWN>
[ 2022-03-29 11:05:37,276 ] [ DEBUG ] [ infer:343 ] Executed reverse infer for node 'cond_2/pred_id'
[ 2022-03-29 11:05:37,276 ] [ DEBUG ] [ infer:347 ] --------------------
[ 2022-03-29 11:05:37,277 ] [ DEBUG ] [ infer:348 ] Reverse infer for cond_2/pred_id
[ 2022-03-29 11:05:37,277 ] [ DEBUG ] [ infer:349 ] Op: Identity
[ 2022-03-29 11:05:37,277 ] [ DEBUG ] [ infer:350 ] Outputs:
[ 2022-03-29 11:05:37,277 ] [ DEBUG ] [ infer:19 ] outputs[0]: shape = <UNKNOWN>, value = <UNKNOWN>
[ 2022-03-29 11:05:37,277 ] [ DEBUG ] [ infer:353 ] Inputs:
[ 2022-03-29 11:05:37,277 ] [ DEBUG ] [ infer:19 ] inputs[0]: shape = <UNKNOWN>, value = <UNKNOWN>
[ 2022-03-29 11:05:37,278 ] [ DEBUG ] [ infer:343 ] Executed reverse infer for node 'cond_2/switch_t'
[ ERROR ] -------------------------------------------------
[ ERROR ] ----------------- INTERNAL ERROR ----------------
[ ERROR ] Unexpected exception happened.
[ ERROR ] Please contact Model Optimizer developers and forward the following information:
[ ERROR ] Exception occurred during running replacer "REPLACEMENT_ID (<class 'openvino.tools.mo.middle.PartialInfer.PartialInfer'>)":
[ ERROR ] Traceback (most recent call last):
File "/usr/local/lib/python3.6/dist-packages/openvino/tools/mo/utils/class_registration.py", line 276, in apply_transform
replacer.find_and_replace_pattern(graph)
File "/usr/local/lib/python3.6/dist-packages/openvino/tools/mo/middle/PartialInfer.py", line 41, in find_and_replace_pattern
partial_infer(graph)
File "/usr/local/lib/python3.6/dist-packages/openvino/tools/mo/middle/passes/infer.py", line 113, in partial_infer
reverse_infer(graph, nodes)
File "/usr/local/lib/python3.6/dist-packages/openvino/tools/mo/middle/passes/infer.py", line 344, in reverse_infer
node.reverse_infer(node)
File "/usr/local/lib/python3.6/dist-packages/openvino/tools/mo/ops/identity.py", line 20, in <lambda>
'reverse_infer': lambda node: reverse_bypass_infer(node, in_ports=[0]),
File "/usr/local/lib/python3.6/dist-packages/openvino/tools/mo/front/common/partial_infer/utils.py", line 332, in reverse_bypass_infer
assert node.is_out_port_connected(0)
AssertionError
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.6/dist-packages/openvino/tools/mo/main.py", line 533, in main
ret_code = driver(argv)
File "/usr/local/lib/python3.6/dist-packages/openvino/tools/mo/main.py", line 489, in driver
graph, ngraph_function = prepare_ir(argv)
File "/usr/local/lib/python3.6/dist-packages/openvino/tools/mo/main.py", line 407, in prepare_ir
graph = unified_pipeline(argv)
File "/usr/local/lib/python3.6/dist-packages/openvino/tools/mo/pipeline/unified.py", line 17, in unified_pipeline
class_registration.ClassType.BACK_REPLACER
File "/usr/local/lib/python3.6/dist-packages/openvino/tools/mo/utils/class_registration.py", line 328, in apply_replacements
apply_replacements_list(graph, replacers_order)
File "/usr/local/lib/python3.6/dist-packages/openvino/tools/mo/utils/class_registration.py", line 318, in apply_replacements_list
num_transforms=len(replacers_order))
File "/usr/local/lib/python3.6/dist-packages/openvino/tools/mo/utils/logger.py", line 112, in wrapper
function(*args, **kwargs)
File "/usr/local/lib/python3.6/dist-packages/openvino/tools/mo/utils/class_registration.py", line 306, in apply_transform
)) from err
Exception: Exception occurred during running replacer "REPLACEMENT_ID (<class 'openvino.tools.mo.middle.PartialInfer.PartialInfer'>)":
[ ERROR ] ---------------- END OF BUG REPORT --------------
OpenVino export failure: Command 'mo --saved_model_dir models/aocr-model --log_level=DEBUG' returned non-zero exit status 1.
6 Respostas
Zulkifli_Intel
Moderador
2.032 Visualizações
Hello Efnna,
Please provide your model, MO command used, and your Operating System to us. This information will help us to investigate this issue further.
Sincerely,
Zulkifli
efnna
Principiante
1.987 Visualizações
I'm using Ubuntu 20.04.3 LTS, ocr tflite model.
Tried submitting input shape [1] but it didn't work at the input of the model:
Help me please
Zulkifli_Intel
Moderador
1.968 Visualizações
Hello Efnna,
Model Optimizer does not support .tflite file to IR format conversion natively. Model Optimizer currently only supports a few frozen quantized topologies hosted on TensorFlow Lite site.
This information is available in the subsection "Supported Frozen Quantized Topologies" under the section Supported Topologies.
However, the frozen model file (.pb file) is required for conversion to IR format by Model Optimizer.
Sincerely,
Zulkifli
efnna
Principiante
1.959 Visualizações
My model consists of a special directory with a .pb file and several subfolders: variables, assets
Sincerely,
Efnna
Zulkifli_Intel
Moderador
1.936 Visualizações
Hello Efnna,
Please share with us your model for replication purposes.
Sincerely,
Zulkifli
Zulkifli_Intel
Moderador
1.875 Visualizações
Hello Efnna,
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
Sincerely,
Zulkifli
Responder
