OpenVINO FPGA installation problem
Wang__Thomas
Hi, I'm new in OpenVINO. I followed the installation guide from https://docs.openvinotoolkit.org/2019_R1/_docs_install_guides_installing_openvino_linux_fpga.html
and successfully completed the two demos ./demo_squeezenet_download_convert_run.sh and ./demo_security_barrier_camera.sh.
But unfortunately, as I'm installing the fpga_support_files, it turns out an error at the last step: aocl diagnose.
My device is HERO
OS: Ubuntu 16.04 FPGA for OpenCL Linux x86-64
The details show as follows;
robot@hero:~$ source /home/robot/下載/fpga_support_files/setup_env.sh
Adding to Path (OpenVINO AOCL)
INTELFPGAOCLSDKROOT is set to /opt/altera/aocl-pro-rte/aclrte-linux64. Using that.
Found Quartus at /opt/altera/aocl-pro-rte/aclrte-linux64/bin  will be using that
AOCL_BOARD_PACKAGE_ROOT is set to /opt/altera/aocl-pro-rte/aclrte-linux64/board/a10_1150_sg1. Using that.
Adding /opt/altera/aocl-pro-rte/aclrte-linux64/bin to PATH
Adding /opt/altera/aocl-pro-rte/aclrte-linux64/host/linux64/lib to LD_LIBRARY_PATH
Adding /opt/altera/aocl-pro-rte/aclrte-linux64/board/a10_1150_sg1/linux64/lib to LD_LIBRARY_PATH
[setupvars.sh] OpenVINO environment initialized
robot@hero:~$ aocl diagnose
Warning:
No devices attached for package:
Unable to find the kernel mode driver.
Please make sure you have properly installed the driver. To install the driver, run
      aocl install
DIAGNOSTIC_FAILED
Call "aocl diagnose <device-names>" to run diagnose for specified devices
Call "aocl diagnose all" to run diagnose for all devices
I'll be appreciate if anyone can give me some suggestion.
Kenneth_C_Intel
Hi, can you check this page https://software.intel.com/en-us/openvino-toolkit/hardware and check to see if your FPGA is one of the supported ones around the middle of the page?
FGale7
Im having the same problem, i installed Openvino 2019 R1.01 and follow the instructions on intel website to install it, i am running bot examples properly using CPU but i m not able to configure the FPGA board to run it.
I have a Arria 10GX FPGA development kit installed according to the recommendations here:
https://docs.openvinotoolkit.org/2019_R1.01/_docs_install_guides_GX_Configure_2019R1.html
i was able to load the top.so file and max5_150.pof files. I run aocl install using the files on the fpga_suppport_files folder for the board a10_1150_sg1, reboot and then running the aocl diagnose command i got this output:
aoc was not found, but aocl was found. Assuming only RTE is installed.
dennis@Laplace:~$ aocl diagnose
INTELFPGAOCLSDKROOT is set to /opt/altera/4.15.0-54-genericaocl-pro-rte/aclrte-linux64. Using that.
Warning:
--------------------------------------------------------------------4.15.0-54-generic
      aocl install
DIAGNOSTIC_FAILED
Warning:
      aocl install
DIAGNOSTIC_FAILED
Does anyone knows what the problem is and how to fix it?
I am using Quartus 18.1 lite.
the kernel version is: 4.15.0-54-generic4.15.0-54-generic
ubuntu 16.04
thanks in advance.
NSVR
Did you solve this issue. Please post here I am having this problem for the last two months
SHENG__LEE
I have met the same problem as you ,and my device is HERO platform too,I have run eveything with OpenCL OK,however ,when I installed OpenVINO and run demo_security_barrier_camera.sh.I have met the same problem as you are.may you have solved this problem?
thanks in advace.
