OpenVINO Model Optimizer Error of tensorflow model
park__kyungja
I'm trying to convert custom tensorflow  model to IR with Model Optimizer.
But, I've got error!
here are my command and error message.
C:\Program Files (x86)\IntelSWTools\openvino_2019.1.133\deployment_tools\model_optimizer>python mo_tf.py --input_model d:\openVINO\frozen_model_tf_1.14.pb --input keep_probabilty,input_image --input_shape (1),(1,40,40,1) --output inference/prediction --output_dir d:\openVINO
Model Optimizer arguments:
Common parameters:
        - Path to the Input Model:      d:\openVINO\frozen_model_tf_1.14.pb
        - Path for generated IR:        d:\openVINO
        - IR output name:       frozen_model_tf_1.14
        - Log level:    ERROR
        - Batch:        Not specified, inherited from the model
        - Input layers:         keep_probabilty,input_image
        - Output layers:        inference/prediction
        - Input shapes:         (1),(1,40,40,1)
        - Mean values:  Not specified
        - Scale values:         Not specified
        - Scale factor:         Not specified
        - Precision of IR:      FP32
        - Enable fusing:        True
        - Enable grouped convolutions fusing:   True
        - Move mean values to preprocess section:       False
        - Reverse input channels:       False
TensorFlow specific parameters:
        - Input model in text protobuf format:  False
        - Path to model dump for TensorBoard:   None
        - List of shared libraries with TensorFlow custom layers implementation:        None
        - Update the configuration file with input/output node names:   None
        - Use configuration file used to generate the model with Object Detection API:  None
        - Operations to offload:        None
        - Patterns to offload:  None
        - Use the config file:  None
Model Optimizer version:        2019.1.0-341-gc9b66a2
[ ERROR ]  Can't permute attrs for node EltwiseReshapeNormalization. Error message: only integer scalar arrays can be converted to a scalar index
Please, help me!!
Shubha_R_Intel
Dear park, kyungja,
I'm seeing  frozen_model_tf_1.14 everywhere but Model Optimizer only supports up to Tensorflow 1.12 today.
shubha
park__kyungja
Dear, shubha,
Thank you for your quick reply.
Actually, I produced a frozen model on tensorflow 1.9 first
It gave me a same error message.
So, I upgraded tensorflow 1.14 and produced a frozen model on it.
Is any possible other reason?
Thanks anyway
// my model info
C:\Program Files (x86)\IntelSWTools\openvino_2019.1.133\deployment_tools\model_optimizer\mo\utils>python summarize_graph.py --input_model "d:\openVINO\frozen_model_tf_1.9.pb"
2 input(s) detected:
Name: keep_probabilty, type: float32, shape: <unknown>
Name: input_image, type: float32, shape: (-1,40,40,1)
1 output(s) detected:
Shubha_R_Intel
Dear park, kyungja,
Can you tell me the kind of Tensorflow model you're having issues with ? Is it an Object Detection API model ? SSD ? Faster RCNN ? If it's a Tensorflow Object Detection API model, then you must follow the below instructions:
http://docs.openvinotoolkit.org/latest/_docs_MO_DG_prepare_model_convert_model_tf_specific_Convert_Object_Detection_API_Models.html
Please report back here with your results.
Shubha
park__kyungja
Dear, Shubha
My model is a kind of semantic segmentation.
It's a modified model of FCN.
It works fine in Ubuntu system with NVIDIA GPU.
Kyungja
Shubha_R_Intel
Dear park, kyungja,
Please run downloader.py under C:\Program Files (x86)\IntelSWTools\openvino_2019.1.148\deployment_tools\tools\model_downloader . Do python3 downloader.py --all . After completing that you will see a few semantic segmentation models that we also support, cascaded_unet, deeplab, dilation. Is the model you're trying one of these ?
If it's not, please give me a link to your model (I assume that it's a public model).
Shubha
park__kyungja
Dear Shubha,
I've already tested public semantic segmentation models.
There are no problem.
I want to have application specific model.
I designed my network and learned the model with my own image sets.
I can't give you my model publicly.
But, I can send it to you by email.
Please, let me know your email address.
Kyungja
Shubha_R_Intel
Dear park, kyungja,
I have PM'd you so that you may send me the model privately.
Appreciate your cooperation.
Thanks !
Shubha
