6577 Discussions
OpenVINO Model optimizer doesn't convert all output layers
Reinberger__Thomas
I tried to convert the posenet model (https://github.com/tensorflow/tfjs-models/tree/master/posenet) using https://github.com/oveddan/posenet-for-installations which converts the Tensorflow js model back to Tensorflow and then to a CoreML model.
The CoreML model contains four output layers: heatmap,offset_2,displacement_fwd_2,displacement_bwd_2
When I create the IR using the OpenVINO model optimizer, there seems to be only one output layer: heatmap, even if I use the specify the output layers using
--output heatmap,offset_2,displacement_fwd_2,displacement_bwd_2
, although I don't get any error message during conversion (which I get if I specify some bogus output layer names).
I should mention that I'm new to ML and Computer Vision.
Any idea what I'm doing wrong?
Cheers
Thomas
