OpenVINO model optimization - Detected not satisfied dependencies
chen__xq
I have viewed all related posts but can't get help.
hardware: LattePanda Delta, Processor Intel(R)  Celeron(R) N4100 CPU @ 1.10GHz, Installed RAM 4G.
System type: 64-bit operating system, x64-based processor
Boot from flash disk which installed WTG, windows 10 Education, OS build 17134.1
Python version: 3.6.5
These paths are added to the environment variables:
C:\Users\cxq\AppData\Local\Programs\Python\Python36\Scripts\
C:\Program Files\CMake\bin
%USERPROFILE%\AppData\Local\Microsoft\WindowsApps
C:\ProgramFiles(x86)\IntelSWTools\openvino\deployment_tools\inference_engine\bin\intel64\Release
C:\Users\cxq\AppData\Local\Programs\Python\Python36\Lib\site-packages\openvino\inference_engine
To run install_prerequisites_tf.bat, all satisfied
C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\install_prerequisites>install_prerequisites_tf.bat
Python 3.6.5
ECHO is off.
Requirement already satisfied: tensorflow<2.0.0,>=1.2.0 in c:\users\cxq\appdata\local\programs\python\python36\lib\site-packages (from -r ..\requirements_tf.txt (line 1)) (1.9.0)
Requirement already satisfied: networkx>=1.11 in c:\users\cxq\appdata\roaming\python\python36\site-packages (from -r ..\requirements_tf.txt (line 2)) (2.4)
Requirement already satisfied: numpy>=1.12.0 in c:\users\cxq\appdata\local\programs\python\python36\lib\site-packages (from -r ..\requirements_tf.txt (line 3)) (1.16.6)
Requirement already satisfied: defusedxml>=0.5.0 in c:\users\cxq\appdata\roaming\python\python36\site-packages (from -r ..\requirements_tf.txt (line 4)) (0.6.0)
Requirement already satisfied: protobuf>=3.4.0 in c:\users\cxq\appdata\roaming\python\python36\site-packages (from tensorflow<2.0.0,>=1.2.0->-r ..\requirements_tf.txt (line 1)) (3.6.1)
Requirement already satisfied: absl-py>=0.1.6 in c:\users\cxq\appdata\roaming\python\python36\site-packages (from tensorflow<2.0.0,>=1.2.0->-r ..\requirements_tf.txt (line 1)) (0.9.0)
Requirement already satisfied: six>=1.10.0 in c:\users\cxq\appdata\roaming\python\python36\site-packages (from tensorflow<2.0.0,>=1.2.0->-r ..\requirements_tf.txt (line 1)) (1.15.0)
Requirement already satisfied: astor>=0.6.0 in c:\users\cxq\appdata\roaming\python\python36\site-packages (from tensorflow<2.0.0,>=1.2.0->-r ..\requirements_tf.txt (line 1)) (0.8.1)
Requirement already satisfied: setuptools<=39.1.0 in c:\users\cxq\appdata\local\programs\python\python36\lib\site-packages (from tensorflow<2.0.0,>=1.2.0->-r ..\requirements_tf.txt (line 1)) (39.1.0)
Requirement already satisfied: gast>=0.2.0 in c:\users\cxq\appdata\roaming\python\python36\site-packages (from tensorflow<2.0.0,>=1.2.0->-r ..\requirements_tf.txt (line 1)) (0.2.2)
Requirement already satisfied: grpcio>=1.8.6 in c:\users\cxq\appdata\roaming\python\python36\site-packages (from tensorflow<2.0.0,>=1.2.0->-r ..\requirements_tf.txt (line 1)) (1.29.0)
Requirement already satisfied: tensorboard<1.10.0,>=1.9.0 in c:\users\cxq\appdata\local\programs\python\python36\lib\site-packages (from tensorflow<2.0.0,>=1.2.0->-r ..\requirements_tf.txt (line 1)) (1.9.0)
Requirement already satisfied: wheel>=0.26 in c:\users\cxq\appdata\roaming\python\python36\site-packages (from tensorflow<2.0.0,>=1.2.0->-r ..\requirements_tf.txt (line 1)) (0.34.2)
Requirement already satisfied: termcolor>=1.1.0 in c:\users\cxq\appdata\roaming\python\python36\site-packages (from tensorflow<2.0.0,>=1.2.0->-r ..\requirements_tf.txt (line 1)) (1.1.0)
Requirement already satisfied: decorator>=4.3.0 in c:\users\cxq\appdata\roaming\python\python36\site-packages (from networkx>=1.11->-r ..\requirements_tf.txt (line 2)) (4.4.2)
Requirement already satisfied: werkzeug>=0.11.10 in c:\users\cxq\appdata\roaming\python\python36\site-packages (from tensorboard<1.10.0,>=1.9.0->tensorflow<2.0.0,>=1.2.0->-r ..\requirements_tf.txt (line 1)) (1.0.1)
Requirement already satisfied: markdown>=2.6.8 in c:\users\cxq\appdata\roaming\python\python36\site-packages (from tensorboard<1.10.0,>=1.9.0->tensorflow<2.0.0,>=1.2.0->-r ..\requirements_tf.txt (line 1)) (3.2.2)
Requirement already satisfied: importlib-metadata; python_version < "3.8" in c:\users\cxq\appdata\roaming\python\python36\site-packages (from markdown>=2.6.8->tensorboard<1.10.0,>=1.9.0->tensorflow<2.0.0,>=1.2.0->-r ..\requirements_tf.txt (line 1)) (1.6.1)
Requirement already satisfied: zipp>=0.5 in c:\users\cxq\appdata\roaming\python\python36\site-packages (from importlib-metadata; python_version < "3.8"->markdown>=2.6.8->tensorboard<1.10.0,>=1.9.0->tensorflow<2.0.0,>=1.2.0->-r ..\requirements_tf.txt (line 1)) (3.1.0)
Warning: please expect that Model Optimizer conversion might be slow.
You can boost conversion speed by installing protobuf-*.egg located in the
"model-optimizer\install_prerequisites" folder or building protobuf library from sources.
For more information please refer to Model Optimizer FAQ, question #80.
But when run the model optimizer, its says "Detected not satisfied dependencies"
C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer>python mo.py --input_model "D:\Chenxq\inception_v1.frozen.pb"
Model Optimizer arguments:
Common parameters:
        - Path to the Input Model:      D:\Chenxq\inception_v1.frozen.pb
        - Path for generated IR:        C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\.
        - IR output name:       inception_v1.frozen
        - Log level:    ERROR
        - Batch:        Not specified, inherited from the model
        - Input layers:         Not specified, inherited from the model
        - Output layers:        Not specified, inherited from the model
        - Input shapes:         Not specified, inherited from the model
        - Mean values:  Not specified
        - Scale values:         Not specified
        - Scale factor:         Not specified
        - Precision of IR:      FP32
        - Enable fusing:        True
        - Enable grouped convolutions fusing:   True
        - Move mean values to preprocess section:       False
        - Reverse input channels:       False
TensorFlow specific parameters:
        - Input model in text protobuf format:  False
        - Path to model dump for TensorBoard:   None
        - List of shared libraries with TensorFlow custom layers implementation:        None
        - Update the configuration file with input/output node names:   None
        - Use configuration file used to generate the model with Object Detection API:  None
        - Use the config file:  None
Model Optimizer version:
[ ERROR ]
Detected not satisfied dependencies:
        tensorflow: not installed, required: >= 1.2.0
        tensorflow: not installed, required: < 2.0.0
I noticed that this is a very common error when we want to generate IR.
I encountered the same problem several days ago when I did it on my own computer. I fixed it by installing TensorFlow 1.9 from the path "C:\Users\Administrator\AppData\Local\Programs\Python\Python36\Scripts" manually. But it didn't work today.  It really makes me frustrated.
So how to fix it in a normal way?
Thank you in advance!
Iffa_Intel
Greetings,
Yes,the most obvious problem that could be seen in the
Probably you can try to install the tensorflow with the compatible version as stated in the error and put it in your environment PATH.
Hope my answer helps!
Sincerely,
Iffa
