OpenVINO supported device list
jasonsloan
My device:           Intel(R) Core(TM) i3-6100 CPU @ 3.70GHz
My model:           YOLOv5s
Phenomenon:     No acceleration effect.
Question:
I tested running YOLOv5 with the device above, and result was no acceleration effect.
I tested the same code with another device which is "Intel(R) Xeon(R) CPU E5-2640 v4 @ 2.40GHz" and it aquired an almost 39% speed boost.
Did it mean OpenVINO dont support " Intel(R) Core(TM) i3-6100 CPU @ 3.70GHz"?
Or may I get an OpenVINO supported device list?
jasonsloan
Hi Zulkifli,
Thanks for your reply.
I checked the link you mentioned above.
I found that one of the supported devices list is "
6th to 13th generation Intel® Core™ processors" .
And my device "Intel(R) Core(TM) i3-6100 CPU @ 3.70GHz" is the 6th generation Intel® Core™ processor which is included.
But as I described above, there was no acceleration effect on my device with OpenVINO.
So I guess maybe OpenVINO dont support " Intel(R) Core(TM) i3-6100 CPU @ 3.70GHz"?
Zulkifli_Intel
Hi jasonsloan,
Thank you for reaching out.
You can check the system requirements for OpenVINO here.
Zulkifli
jasonsloan
Hi Zulkifli,
Zulkifli_Intel
Hi jasonsloan,
Yes, you are right. Based on system requirements, OpenVINO does support Gen 6 processors. For Core i3 processor, it has low processing power compared to the Xeon processor. That is one of the reasons why the inference speed is not significant for Intel(R) Core(TM) i3-6100 CPU.
You can refer to Benchmark Result to see the CPUs' performances.
Zulkifli
Zulkifli_Intel
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
Zulkifli
