6595 Discussions
OpenVino Installation error on Macbook Pro mid 2012
sarang_sonar
After successfully installing Openvino version 2021.1 on my MacBook pro mid 2012, I am not able to run the jupyter notebooks and getting a import errors like
from openvino.inference_engine import IENetwork, IECore
ModuleNotFoundError: No module named 'openvino'
 I have checked the directory location of the installation of OpenVino and made it similar to the Anaconda directory. Even, after directly installing OpenVino in the same directory of Anaconda , this error persists.
Another type of error that I encountered, when I installed version 2020 was the IECore import error.
I have also checked the same Jupyter notebook on the later versions of MacBook (2019), but still the error persists. I have tried installing Openvino directly in python, which also again gives different errors. The same issue doesn't happen in Windows installation. Please let me know what is the cause of this issue. I am also attaching the utils folder which is giving the errors because of the version incompatibility.
Victor_G_Intel
Hello sarang_sonar,
Your query will be best answered by our Open VINO support team. We will help you to move this post to the designated team to further assist you.
Victor G
Intel Customer Support
Iffa_Intel
Greetings,
You need to initialize the setupvars each time you open a new terminal. Unless you set it permanently to auto init once a terminal is opened.
The setupvars inits all pre-requisites required for openvino to work. So if you call the "from openvino.inference_engine import IENetwork" without the setupvars first, you will get that kind of error.
Here is the official documentation for MacOS: https://docs.openvinotoolkit.org/2021.3/openvino_docs_get_started_get_started_macos.html
Sincerely,
Iffa
Iffa_Intel
Greetings,
Intel will no longer monitor this thread since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Sincerely,
Iffa
