OpenVino on Atom E3845?
Joe_Speed
Does OpenVino support Atom E3845? What are the caveats?
nikos1
Valued Contributor I
Hi Joe, the E3845 is a bit older, not officially supported according to
https://software.intel.com/en-us/openvino-toolkit
I tried on the more recent Atoms E3930 and E3950 and was fine.  The caveats would be slower inference fps as they have weaker CPU and GPU.
Cheers,
Nikos
Monique_J_Intel
Hi Joe,
As Niko stated, OpenVINO should theoretically work on the atom processor however CPU and GPU are poor in performance as most atoms have only 2 core processors. I've also experienced that if you have to use the atom processor that GPU gives you better FPS than CPU.
Kind Regards,
Monique Jones
Yannis__James
Jones, Monique (Intel) wrote:
Hi Joe,
Kind Regards,
Monique Jones
I am using E3950 on ubuntu 16.04, but I can only run CPU. GPU is not working because OPENCL is 1.2, not 2.1. How could I activate GPU on E3950?
tenin__roman
Hi Joe,
Kind Regards,
Monique Jones
Hi, I have atom-e3845 and openvino 2020.1.033 running on Windows 10 and I get following error:
[ ERROR ] Failed to create plugin C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\inference_engine\bin\intel64\Release\MKLDNNPlugin.dll for device CPU
Please, check your environment
Cannot load library 'C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\inference_engine\bin\intel64\Release\MKLDNNPlugin.dll': 1114 from cwd: C:\Users\IZuser\Documents\Intel\OpenVINO\inference_engine_samples_build\intel64\Release
setupvars was called before
Isn't it connected with CPU? I looked into MKLDNNPlugin.dll with dependancy walker, all dependecies seems to be satisfied
