Does OpenVino support Atom E3845? What are the caveats?
Hi Joe, the E3845 is a bit older, not officially supported according to
https://software.intel.com/en-us/openvino-toolkit
I tried on the more recent Atoms E3930 and E3950 and was fine. The caveats would be slower inference fps as they have weaker CPU and GPU.
Cheers,
Nikos
Hi Joe,
As Niko stated, OpenVINO should theoretically work on the atom processor however CPU and GPU are poor in performance as most atoms have only 2 core processors. I've also experienced that if you have to use the atom processor that GPU gives you better FPS than CPU.
Kind Regards,
Monique Jones
Jones, Monique (Intel) wrote:Hi Joe,
Kind Regards,
Monique Jones
I am using E3950 on ubuntu 16.04, but I can only run CPU. GPU is not working because OPENCL is 1.2, not 2.1. How could I activate GPU on E3950?
Kind Regards,
Monique Jones
Hi, I have atom-e3845 and openvino 2020.1.033 running on Windows 10 and I get following error:
[ ERROR ] Failed to create plugin C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\inference_engine\bin\intel64\Release\MKLDNNPlugin.dll for device CPU
Please, check your environment
Cannot load library 'C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\inference_engine\bin\intel64\Release\MKLDNNPlugin.dll': 1114 from cwd: C:\Users\IZuser\Documents\Intel\OpenVINO\inference_engine_samples_build\intel64\Release
setupvars was called before
Isn't it connected with CPU? I looked into MKLDNNPlugin.dll with dependancy walker, all dependecies seems to be satisfied
![](/skins/images/45C6C2D737ED71F4C51F0145C8CB1E9C/responsive_peak/images/icon_anonymous_message.png)
