6605 Discussions
Openvino does not detect Intel GPU in Ubuntu Docker
aamirkhann
I am pretty new to this Openvino and Intel GPU world, I have pulled openvino/openvino_tensorflow_ubuntu18_runtime:2.0.0 docker image and when I run the OpenVINO_TensorFlow_classification_example.ipynb it only sees "CPU" when listing backends.
However, when running lspci -nn -s 0:002.0 inside the docker container it outputs:
00:02.0 VGA compatible controller [0300]: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics Controller [8086:0412] (rev 06)
I have tried to run a simpler python script to only print the openvino backends but I keep getting only the CPU backend.
What am I missing here? Is my iGPU not compatible with OpenVino? Am I missing some driver or some kind of configuration?
My native OS is Debian11.
Peh_Intel
Hi aamirkhann,
I also not able to launch the Jupyter server with iGPU access even though attached GPU to the container and installed the kernel driver on host machine.
We will investigate this issue and get back to you at the earliest.
Peh
Azizul_Intel
Hi aamirkhann,
Can you share your system configuration as below for further understanding and troubleshooting purposes.
  1. CPU Info
  2. OCL Driver version for your GPU
BR,
Azizul
Peh_Intel
Hi aamirkhann,
The reported issue has been resolved in OpenVINO runtime 2.1.0 as below:
docker pull openvino/openvino_tensorflow_ubuntu18_runtime:2.1.0
docker pull openvino/openvino_tensorflow_ubuntu20_runtime:2.1.0
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Peh
