Yolov3 example code
Mauricio
Hi.
I have trying to use a yolov3 model with OpenVINO 2021.4.1.
Is there an example code that uses a yolov3 model?
Because from my understanding, after getting the output that appears in the OpenVINO documentation page (https://docs.openvino.ai/2021.4/omz_models_model_yolo_v3_tf.html), a post processing of NMS (non maximun suppression) and other steps must be performed to get the final list of bonding boxes.
Mauricio.
Hairul_Intel
Hi Mauricio,
OpenVINO™ Toolkit does provide various example codes and demo applications that supports Intel pre-trained models or public pre-trained models which are available from Open Model Zoo Demos.
For your information, you can run the Object Detection Python Demo with yolo-v3-tf model. Here is the result for running the demo with yolo-v3-tf model:
Additionally, you can view the Object Detection Python Demo code from Open Model Zoo GitHub repository or the demo is available after installation in the following directory:
<INSTALL_DIR>\deployment_tools\open_model_zoo\demos\object_detection_demo\python\object_detection_demo.py
Hairul
Hairul_Intel
Hi Mauricio,
Hairul
Hairul_Intel
Hi Mauricio,
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Hairul
