6577 Discussions
Openvino error:expected: 'pin.oid < (int)netInputLayer.shapes.size()
AyasaYasca
I tried to make a program about FaceMask-Detection.Before,my programme could run successfully with the caffe model.However,When I turn caffe to ir model,it has problems as follows.
gdb debug:
i guess the problem is model'format.but i cant sovle it
pls help me.
Wan_Intel
Hi AyasaYasca,
Could you please share the following details with us for further investigation?
·      Which version of the OpenVINO™ toolkit are you using?
·      Hardware specifications
·      Are you using custom demo application or Open Model Zoo Demo?
·      Are you using custom model or Open Model Zoo Demo?
Wan
AyasaYasca
Hello wan:
Thank you for your prompt reply.
Run -environment:
rasberry3B+
The version of openvino:
l_openvino_toolkit_runtime_raspbian_p_2020.4.287.tgz
Both  caffe and ir  model are here.
If you want the source code later, I can provide it to you.
Wan_Intel
Hi AyasaYasca,
I’ve checked your IR model with OpenVINO™ Benchmark Python tool as shown as follows:
Did you create your application from scratch? You can share it here for further investigation.
Wan
AyasaYasca
Hello wan:
Here is my program.
Thanks for your help. ovo
Wan_Intel
Hi AyasaYasca,
I noticed that you are using CPU plugin in your application (Line 52).
   this->net.setPreferableTarget(dnn::DNN_TARGET_CPU);
For your information, CPU plugin is not supported by OpenVINO™ toolkit for Raspbian Operating System. You must use Intel® Neural Compute Stick 2 with Raspberry Pi and use MYRIAD plugin instead of CPU plugin.
Please refer to Development and Target Platforms in Install OpenVINO™ toolkit for Raspbian OS and Supported Devices for more information.
Wan
AyasaYasca
Hi Wan,
Thank for your patient reply.
Although I obey your order to change the error code ,it still has problems:
firstly, I changed the parament ,it still has error
secendly, I deleted the code shown above .But the else error occur
I guess the reason as follows:
the first one is the incorrect version of the openvino
another is the false ir format
Because English is not my first language. My expression may confuse you .....
Wan_Intel
Hi AyasaYasca,
Do you use Intel® Neural Compute Stick 2 with Raspberry Pi when changing the plugin to MYRIAD plugin?
Wan
AyasaYasca
AyasaYasca
Wan_Intel
Hi AyasaYasca,
I noticed that the error you encountered:
“'inputShapeLimitation.size()' is 2 must be equal to 'blobShape.size()' is 4”
 was due to incompatible sizes used which related to the blob size. You may refer to here for more information.
I suggest that you use OpenVINO™ Runtime API to Implement Inference Pipeline to integrate OpenVINO™ with your application.
You may refer to the following inference engine samples:
·      Hello Classification C++ Sample
·      Image Classification Async C++ Sample
Wan
Wan_Intel
Hi AyasaYasca,
Thanks for your question.
This thread will no longer be monitored since we have provided information.
If you need any additional information from Intel, please submit a new question.
Wan
