Openvino extension
Erwin8
Tried to make my own text spotting application, but did not work with the "text-spotting-0003-detector" and the "text-spotting-0003-recognizer-decoder" model on windows. Could not load it into the IECore().
Think it is the extension: "RuntimeError: Cannot create Range layer ReduceMin_589/axes id:445". How do I add the extension on windows 10. Did not find the .so file in the system?
Peh_Intel
Hi Erwin,
Greetings to you.
For your information, OpenVINO™ Toolkit also provides one text spotting demo and I’ve validated that demo works well with the text-spotting-0003-detector, text-spotting-0003-recognizer-encoder and text-spotting-0003-recognizer-encoder models on OpenVINO™ 2021.2  without specifying any extension library.
Please note that text-spotting-0003 model can only work on OpenVINO™ 2021.2. I’ve also validated that the demo failed to work with text-spotting-0003 model on various versions of OpenVINO™ (2020.1, 2020.4,2021.1) and resulted in getting different runtime errors. I got the exact runtime error as you when running the demo on OpenVINO™ version 2020.4.
You may refer to the Release Notes for Intel® Distribution of OpenVINO™ Toolkit 2021 under the section “Open Model Zoo”.
https://software.intel.com/content/www/us/en/develop/articles/openvino-relnotes.html
Please check the OpenVINO™ version that you’re using. It is always advisable to upgrade OpenVINO™ to the latest version or use the Model Downloader in OpenVINO™ that you’re using to download the model. If you’re already using the latest OpenVINO™ version, please do me a favor to try running the text spotting demo and share the result with me.
Peh
Erwin8
Hi Peh,
Thanks for the answer.
I installed the Openvino 2021.2 version (Windows 10) but am using Anaconda and the last version there is 2020.4. So I think Anaconda only takes into account this version.
Is there some way to have anaconda which works with the latest version of Openvino?
Erwin
Peh_Intel
Hi Erwin,
You can install the runtime package for the latest version of OpenVINO™ version with these commands:
conda install -c anaconda python=3.7
conda install openvino-ie4py -c intel
OR
You can create a virtual environment and install the runtime package for the latest version of OpenVINO™ version with these commands:
conda create -n <name> python=3.7
conda activate <name>
Peh
Erwin8
Hi Peh,
Great, it works with creating a new environment. The update of the old one did not work, maybe I have to uninstall openvino and then reinstall it.
However, an error occurred with the new OpenVion version:
not_supported_layers = [l for l in self.network.layers.keys() if l not in supported_layers]
AttributeError: 'openvino.inference_engine.ie_api.IENetwork' object has no attribute 'layers'
So, with the new version, I no longer have to search for supported layers, right?
Erwin
Peh_Intel
Hi Erwin,
This property, 'ie_api.IENetwork.layers' is deprecated and removed in OpenVINO™ version 2021.2. Please refer to this thread that had well discussed the same issue before. There is also a shared workaround available in that thread.
You can try running your application without searching for the supported layers or use the nGraph function's get_ordered_ops method.
Peh
Peh_Intel
Hi Erwin,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Peh
