6571 Discusiones
Openvino: running an inference engine with a model yields "error access memory" - unknown causes
centroid
Principiante
737 Vistas
I am on Raspbian OS and I run the following code:
pi@raspberrypi:~/openvino/inference_engine_cpp_samples_build/armv7l/Release $ sudo ./hello_classification /home/pi/openvino/open_model_zoo/tools/downloader/intel/emotions-recognition-retail-0003/FP16/emotions-recognition-retail-0003.xml /home/pi/Downloads/robert-de-niro.jpg MYRIAD
I get the following error output:
"memory access error"
[the german output message is "Speicherzugriffsfehler"]
Anyone knows the cause and how to address this error?
0 kudos
2 Respuestas
Peh_Intel
Moderador
719 Vistas
Hello centroid,
You’re getting the error because the Hello Classification C++ Sample does not support the emotions-recognition-retail-0003 model.
You may refer to the documentation about this disclaimer:
“There is also an API introduced to crop a ROI object and set it as input without additional memory re-allocation. To properly demonstrate this API, it is required to run several networks in pipeline which is out of scope of this sample. “
The emotions-recognition-retail-0003 model is supported by the Interactive Face Detection Demo.
Peh
Peh_Intel
Moderador
699 Vistas
Hello centroid,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Peh
Responder
