- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
Hello everyone,
I use the IEI Mustang-V100-MX8 (16 Myriad) with newest OpenVINO toolkit R2019 3.1 to run the HDDL inference by benchmark_app on the Windows 10. I found that the performance will decrease after inference iteration
I iterate the 10 times for my test with the following command
benchmark_app.exe -m C:\Users\user\Desktop\temp\barry\OpenVINO_2019R310\test_data\MobileNet-SSD\VINO_2019_R310\FP32\MobileNet-SSD.xml -i C:\Users\user\Desktop\temp\barry\OpenVINO_2019R310\test_data\testSSD.bmp -d HDDL -api sync -nireq 1
Here is the summary from my test. By the way, the detail is in the attached file:
Count: 1742 iterations
Duration: 60010.53 ms
Latency: 34.50 ms
Throughput: 28.99 FPS
Temperature [74.1] [66.2] [73.7] [71.9] [64.4] [64.4] [63.4] [66.4] [64.6] [73.5] [73.7] [74.5] [65.2] [74.1] [65.8] [72.7]
Count: 1530 iterations
Duration: 60120.30 ms
Latency: 34.49 ms
Temperature [75.3] [67.3] [73.9] [72.1] [65.0] [64.8] [64.0] [67.1] [64.6] [74.9] [74.7] [74.5] [65.8] [74.3] [66.2]
Count: 1021 iterations
Duration: 60226.78 ms
Latency: 34.58 ms
Throughput: 28.92 FPS
Temperature [75.3] [67.7] [74.9] [72.7] [64.8] [64.8] [64.4] [66.9] [65.0] [75.6] [75.1] [74.9] [65.6] [74.5] [67.1] [73.7]
Count: 691 iterations
Duration: 60001.07 ms
Latency: 35.51 ms
Throughput: 28.16 FPS
Temperature [75.8] [67.5] [74.9] [72.7] [65.2] [65.2] [64.8] [67.7] [65.2] [75.1] [75.3] [75.3] [66.0] [74.9] [66.9] [74.5]
Count: 575 iterations
Duration: 60066.63 ms
Latency: 35.48 ms
Throughput: 28.19 FPS
Temperature [76.4] [67.5] [75.1] [73.3] [65.8] [66.4] [64.6] [67.5] [65.6] [76.2] [75.8] [75.8] [67.1] [75.1] [67.3] [74.5]
Count: 533 iterations
Duration: 60064.46 ms
Latency: 35.51 ms
Temperature [76.4] [67.5] [75.3] [73.9] [66.0] [65.0] [64.6] [67.1] [65.6] [76.0] [76.0] [75.6] [66.4] [75.6] [67.1] [74.7]
Count: 521 iterations
Duration: 60005.13 ms
Latency: 35.53 ms
Throughput: 28.15 FPS
Temperature [76.0] [68.3] [75.8] [73.5] [65.4] [65.2] [65.6] [67.9] [65.4] [76.0] [75.6] [76.2] [66.9] [76.0] [67.7] [74.3]
Count: 515 iterations
Duration: 60117.44 ms
Latency: 35.50 ms
Throughput: 28.17 FPS
Temperature [77.0] [68.1] [75.8] [74.1] [66.2] [65.8] [65.0] [67.7] [66.0] [76.4] [76.4] [76.0] [67.1] [75.3] [67.3] [75.1]
Count: 509 iterations
Duration: 60147.81 ms
Latency: 35.57 ms
Throughput: 28.11 FPS
Temperature [76.8] [68.5] [75.8] [74.7] [65.6] [65.6] [65.2] [67.7] [65.6] [76.2] [76.0] [76.0] [66.9] [76.0] [67.7] [75.3]
As you can see, the count is decrease after each turn, and HDDL did not seem to enter the throttle state because the temperature is between the 65~76.
I cannot figure out where the problem is. Is there any suggestion? Any help would be appreciated .
Lien copié
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
