Performance of Myriad X
I have followed this guide to install OpenVINO on Raspberry Pi 3.
When I ran the sample object_detection_sample_ssd with model face-detection-adas-0001, I found that the performance of Myriad X is just about 7 FPS.
I also tried to run the same sample by using Myriad 2, and the performance is about 6 FPS.
Then I tried to run the sample benchmark_app with model face-detection-adas-0001, and the performance of Myriad X is about 9 FPS.
I though the performance of Myriad X should be much better than Myriad 2.
Did I do something wrong?
Hi @EdwardLee
Thank you for reaching out. That performance is expected. Here is a discussion thread on the Computer Vision forums that might be useful to you with more compared inference times.
Sahira
