6574 Discussions
Poor inference performance with interleaved network models
Raghavan_S_
When I run a typical convolution network on the CPU, the execution time is very unpredictable.
If I run inferencing (net.infer()) in a loop:
net.infer(input)
net.infer(input)
I get a time of 30 milliseconds with very little variation from run to run.
However, when I interleave multiple networks and invoke them alternately:
net1.infer(input)
net2.infer(input)
net1.infer(input)
net2.infer(input)
the average performance drops significantly to 67 milliseconds.  The worst case is over 200 milliseconds.  Is this a problem with cache performance?  Is there any way to improve this?
Environment:
Processor: core i7 8700K with 32 GB RAM
OS: Ubuntu 16.04
OpenVINO version:
2018.2.319  (dated July 2018)
Network: 4 convolution layers + 3 FC layers
Model file size: ~ 8MB (32 bit float)
Target:  CPU, AVX2 (SSE4 also gives similar performance)
Raghavan
Mark_L_Intel1
Hi Raghavan,
Sorry for the late response because we are busy on multiple requests.
I want to reproduce what you observed, could you tell me the steps?
The model and the sample you are using, which code you used for inference?
Mark
