6614 Discussions
Possible memory corruption and/or race condition bug in async inference API on NCS 2 (MYRIAD X)
EdBordin
I have been trying to hunt down the root cause of a bug we saw in prod where running inference  with a classifier model with the MYRIAD plugin on NCS 2 hardware periodically produces NaN outputs but the same model with the CPU plugin does not. Initially I assumed that differences in FP16/FP32 precision on the activations could be causing numeric instability on the NCS 2. I have now found that in fact I can reproduce this bug just by running parallel inference requests with the async API. With the exact same input and the same model I periodically get results that appear to be corrupted (detected by the presence of NaN values, but there may be other bad outputs I have not detected). I have been able to reproduce this on two different hosts with the following code snippet:
import numpy as np
from openvino.inference_engine import IECore, StatusCode
import pickle
import warnings
core = IECore()
base_dir =  '.'
openvino_xml_path = base_dir+'/intel_model/saved_model.xml'
output_path_fmt = base_dir+"/nandata/nandata_{}.p"
openvino_output_map = {
    "StatefulPartitionedCall/myriad_bug/classifier_out/Sigmoid" : "classifier_out"
batch_size = 16
num_inference_requests = 4
input_length = 10752
dummy_input = {'audio_in':np.random.normal(size=[batch_size,1,input_length,1])}
poll_ms = 1 # add a short wait to prevent the polling loop spinning unnecessarily fast
openvino_plugin_name = "MYRIAD"
# Same issue when running multiple NCS 2 devices via the MULTI plugin:
# myriads = list(dev for dev in core.available_devices if dev.startswith('MYRIAD'))
# assert len(myriads) > 0, 'No myriad X devices found!'
# openvino_plugin_name = "MULTI:" + ','.join(myriads)
network = core.read_network(
    model=openvino_xml_path,
network.batch_size = batch_size
executable_network = core.load_network(
    network,
    device_name=openvino_plugin_name,
    num_requests=num_inference_requests,
# prime the requests
for req in executable_network.requests:
    req.async_infer(dummy_input)
# start hammering
j = 0
while True:
    for i, req in enumerate(executable_network.requests):
        infer_status = req.wait(poll_ms if i == 0 else 0)
        if infer_status == StatusCode.RESULT_NOT_READY:
            continue
        if infer_status != StatusCode.OK:
            warnings.warn(f'Infer request {j} returned {infer_status}')
            continue
        # make sure it's ready
        # (I found in the past - around R2019 - this was necessary when using the
        # C++ API, may not be required in python or with newer OpenVINO)
        req.wait()
        for k, dispname in openvino_output_map.items():
            res = req.output_blobs[k].buffer
            if np.any(np.isnan(res)):
                print('NaN triggered', j, i, dispname, res)
                with open(output_path_fmt.format(j), 'wb') as f:
                    pickle.dump({k: req.output_blobs[k].buffer for k in openvino_output_map}, f)
                break
        # start new req
        if j % 10 == 0:
            print(j)
        j += 1
My manager has told me not to attach the model file publicly but I have permission to provide it privately to an Intel employee over email or other means.
If I had to speculate, it could be that the input shape we are using is an edge case compared to typical image convnets, as it took some trial and error to find a minimal model architecture that allows me to reproduce the bug.
I'm using the openvino-dev package from pypi with python 3.9:
openvino-2021.4.2-3976-cp39-cp39-manylinux2014_x86_64.whl
openvino_dev-2021.4.2-3976-py3-none-any.whl
Peh_Intel
Hi EdBordin,
You are welcome to send your model file and the nandata_{}.p file privately to my email:
yux.chern.peh@intel.com
If possible, do also share your original model (before converting to IR) with me.
Peh
Peh_Intel
Hi EdBordin,
Thanks for sharing your model with us.
I was able to reproduce the issue on my end.
When loading the network with one infer request, I was able to get rid of the NaN output values.
It might be due to the limitation of Intel® Neural Compute Stick 2’s resources and capabilities.
Peh
EdBordin
Hi Peh,
If this is due to a hardware limitation then I would expect that either the model compiler or the MYRIAD plugin could correctly validate that and raise an error rather than leading to this behaviour with corrupted data. Failing that, it would be very helpful if you could work with us to isolate what limitation we are hitting so we can manually avoid it in future models.
Using one request effectively degrades performance to be the same as the synchronous API - we're trying to use this chip for its intended purpose of real time inference at the edge so that's not really a great solution. If we can't resolve this we may have to switch to a different hardware solution.
Ed
Peh_Intel
Hi EdBordin,
I’ve validated that running the test script with HDDL plugin (8 MYRIAD), the output results are smooth.
By the way, I also try few ways to run the test script with Intel® Neural Compute Stick 2 to get rid of the NaN output values. Surprisingly, when enlarging the model input shape, the output results are also smooth. However, changing the model input shape may significantly affect its accuracy. This proposed workaround has to clarify further from your side.
Few changes added to the test script:
input_length = 21504
input_layer = next(iter(network.input_info))
print(f"Input shape: {network.input_info[input_layer].tensor_desc.dims}")
network.reshape({input_layer: [1, 1, 21504, 1] })
Peh
Peh_Intel
Hi EdBordin,
This thread will no longer be monitored since we have provided suggestion and solution. If you need any additional information from Intel, please submit a new question.
Peh
