Installation problem
gb8
I am trying to change test env. from Windows to Linux(wsl2, Ubuntu 20.04).
In download page,
https://www.intel.com/content/www/us/en/developer/tools/openvino-toolkit/download.html
Selection : Dev Tools, Linux, 2022.1 Offline Installer
Then click Download button.
--> No downloads. it was successful sometime before...
gb8
Hairul_Intel
Hi gb8,
Please note that as of OpenVINO 2022.1 release, the OpenVINO Development Tools can only be installed via PyPI.
See Install OpenVINO™ Development Tools for a comprehensive installation guide.
If you're developing in Python, follow these steps under For Python Developer section.
For developing in C++, follow the For C++ Developer section. Please note the following when installing for C++ development:
  • You must install OpenVINO Runtime through an installer first (Linux, Windows, or macOS).
  • Ensure both versions of OpenVINO Runtime and OpenVINO Development tools are the same.
Hairul
gb8
OK. I see.
Problem was I bookmarked the following page for later installation.
(https://www.intel.com/content/www/us/en/developer/tools/openvino-toolkit/download.html)
So it need be removed, redirected, or etc.
Gb8
Hairul_Intel
Hi gb8,
From the link you provided, the installation for OpenVINO 2022.1 Dev Tools is already using PyPI installation as shown below:
Run the following command in your terminal to install OpenVINO Dev Tools using PyPI:
pip install openvino-dev==2022.1.0
Follow the guide on how to Install OpenVINO™ Development Tools for a detailed step-by-step tutorial.
Hairul
Hairul_Intel
Hi gb8,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Hairul
