6605 Discussions
from openvino.model_zoo.model_api.performance_metrics import PerformanceMetrics
gb8
Hi.
I am testing colorization_demo.py from open_model_zoo repo.
cmd :
python colorization_demo.py -i ~/code/datasets/dish.jpg \
-m public/colorization-v2/FP16/colorization-v2.xml
result :
error message is,
Traceback (most recent call last):
File "colorization_demo.py", line 30, in <module>
from images_capture import open_images_capture
File "/home/pi/code/open_model_zoo/demos/common/python/images_capture.py", line 9, in <module>
ModuleNotFoundError: No module named 'openvino.model_zoo.model_api'
So, I tried to debug the file in the VSCode.
Then error message is  same.
2022-03-29 20_17_41-images_capture.py - pi [WSL_ OV_Ub20] - Visual Studio Code.png
For workaround, assign path to 'PerformanceMetrics' to sys.path and modify import statement is working like follows.
sys.path.append('/home/pi/code/notebooks/common/python/openvino/model_zoo/model_api')
from performance_metrics import PerformanceMetrics
But this may not be the solution.
My environment is,
  - Windows WSL, Ubuntu 20.04
gb8
gb8
pip install <omz_dir>/demos/common/py
solved the problem.
Thanks a lot.
gb8
note)
in the install guide page(https://docs.openvino.ai/latest/omz_demos.html), model_api install guide link you send   seems to be broken.
it leads to https://docs.openvino.ai/latest/common/python/openvino/model_zoo/model_api/README.md#installing-python*-model-api-package, and 404 message shows.
gb8
l forgot one more thing. python version is 3.8.
Hairul_Intel
Hi gb8,
I've replicated this issue and received similar results (I've tested with Windows WSL2 Ubuntu 20.04 and Colorization Python Demo).
We're investigating this issue and shall get back to you soon.
Hairul
Vladimir_Dudnik
@gb8 according to OMZ demos description you need to properly initialize environment to run demos, in particular you need to install OMZ Model API python component (to run python based demos), this can be achieved with simple command:
pip install <omz_dir>/demos/common/python
gb8
solved the problem.
Thanks a lot.
gb8
note)
Hairul_Intel
Hi gb8,
Glad to know that your issue has been resolved.
At the moment, the link for the Python Model API Package Installation in the documentation is broken and we have informed the relevant team to reinstate the correct link. Meanwhile, you can follow this Python Model API Package Installation guide on GitHub.
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Hairul
