6627 Discussions
Post-training Optimization Tool API Examples
DarkHorse
I am trying to run this command and I am getting error messages again
https://docs.openvino.ai/2022.3/pot_example_classification_README.html#doxid-pot-example-classification-r-e-a-d-m-e
OS: Windows 11
Python: 3.8.2
OpenVINO_2023
python3 ./classification_example.py -m <PATH_TO_IR_XML> -a <IMAGENET_ANNOTATION_FILE> -d <IMAGES_DIR>
And again I am getting this error messages :
(openvino_env) F:\openvino_env\Scripts>python classification_sample.py -m F:\IR_Models\public\mobilenet-v2-1.0-224\FP32\mobilenet-v2-1.0-224.xml -a F:\ImageNet\val.txt -d F:\ImageNet
F:\openvino_env\lib\site-packages\openvino\offline_transformations\__init__.py:10: FutureWarning: The module is private and following namespace `offline_transformations` will be removed in the future.
warnings.warn(
[ DEBUG ] Creating converter from 7 to 5
[ DEBUG ] Creating converter from 5 to 7
Post-training Optimization Tool is deprecated and will be removed in the future. Please use Neural Network Compression Framework instead: https://github.com/openvinotoolkit/nncf
Nevergrad package could not be imported. If you are planning to use any hyperparameter optimization algo, consider installing it using pip. This implies advanced usage of the tool. Note that nevergrad is compatible only with Python 3.7+
INFO:openvino.tools.pot.pipeline.pipeline:Inference Engine version: 2023.0.1-11005-fa1c41994f3-releases/2023/0
INFO:openvino.tools.pot.pipeline.pipeline:Model Optimizer version: 2023.0.1-11005-fa1c41994f3-releases/2023/0
INFO:openvino.tools.pot.pipeline.pipeline:Post-Training Optimization Tool version: 2023.0.1-11005-fa1c41994f3-releases/2023/0
INFO:openvino.tools.pot.statistics.collector:Start computing statistics for algorithms : DefaultQuantization
INFO:openvino.tools.pot.statistics.collector:Computing statistics finished
INFO:openvino.tools.pot.pipeline.pipeline:Start algorithm: DefaultQuantization
INFO:openvino.tools.pot.algorithms.quantization.default.algorithm:Start computing statistics for algorithm : ActivationChannelAlignment
INFO:openvino.tools.pot.algorithms.quantization.default.algorithm:Computing statistics finished
INFO:openvino.tools.pot.algorithms.quantization.default.algorithm:Start computing statistics for algorithms : MinMaxQuantization,FastBiasCorrection
INFO:openvino.tools.pot.pipeline.pipeline:Finished: DefaultQuantization
Traceback (most recent call last):
File "classification_sample.py", line 245, in <module>
main()
File "classification_sample.py", line 232, in main
compressed_model, pipeline = optimize_model(args)
File "classification_sample.py", line 215, in optimize_model
if not args.keep_uncompressed_weights:
AttributeError: 'Namespace' object has no attribute 'keep_uncompressed_weights'
Any idea on this?
Megat_Intel
Hi DarkHorse,
For your information, I received the same error message " AttributeError: 'Namespace' object has no attribute 'keep_uncompressed_weights' " when running the Quantizing Image Classification Model. From the error message, the error occurs in line 215 during model weights compression.
We have informed the relevant team regarding this issue and we'll provide an update once we receive any confirmation.
On the other hand, it is mentioned in the code that the step that was causing the error is optional. I remove the model compression step in the classification_sample.py code and was able to run the image classification model quantization. I show my results here:
Code Snippet:
Quantization Results:
On the other hand, I ran the OpenVINO™ Benchmark Tool and Classification Python Demo for both the original model (mobilenet-v2-1.0-224) and the quantized model (TensorFlow_Frontend_IR) to compare the results. I share them below:
Benchmark Tool:
  • mobilenet-v2-1.0-224:
  • TensorFlow_Frontend_IR:
Classification Python Demo:
Megat
Megat_Intel
Hi DarkHorse,
Thank you for sharing your findings on the error.
For your information, this issue has been fixed by the Development Team. You can check out the latest Quantizing Image Classification Model, by git pull the latest OpenVINO™ Toolkit master branch.
Megat
Megat_Intel
Hi DarkHorse,
This thread will no longer be monitored since we have provided a suggestion. If you need any additional information from Intel, please submit a new question.
Megat
