6573 Discussions
openvino is needed installed in a user computer
pingdan
hi, I have some codes with openvino and compiled to an exe file, now I want to put this exe file in the user computer, does the computer need to install openvino and set the system environment parameter?
Megat_Intel
Hi Pingdan,
Yes, you need to install the OpenVINO™ Toolkit and configure the correct environment parameters. For the deep learning inference to work, OpenVINO™ Runtime/Inference Engine is required to read the supported model and execute it on preferred devices (e.g. CPU, GPU, GNA, etc.). OpenVINO™ Runtime uses a plugin architecture that contains implementation for inference on the particular Intel® hardware device.
On the other hand, we suggest installing the OpenVINO™ Runtime package for the user's computer since you already have a model and code to run inference on. Hope this helps.
Megat
Megat_Intel
Hi Pingdan,
This thread will no longer be monitored since we have provided a suggestion. If you need any additional information from Intel, please submit a new question.
Megat
