6575 Discussions
Problems using OpenVino network inside python class
Nikolaev__Viktor
I write simple code for objects detection . But my application crashes when I try to run this code
from  openvino.inference_engine import IENetwork, IEPlugin
import numpy as np
import os
class OpenVinoDetector():
    def __init__(self, model_path):
        # read the model
        self.plugin = IEPlugin(device="CPU", plugin_dirs=None)
        self.plugin.add_cpu_extension('cpu_extension.dll')
        net = IENetwork.from_ir(model=model_path, \
                                weights=os.path.splitext(model_path)[0] + ".bin")
        self.network = self.plugin.load(network=net, num_requests=2)
        # input and output
        self.input_blob = next(iter(net.inputs))
        self.out_blob = next(iter(net.outputs))
    def detect(self, frame):
        cur_request_id = 0
        self.network.start_async(request_id=cur_request_id, inputs={self.input_blob: frame})
        if self.network.requests[cur_request_id].wait(-1) == 0:
            res = self.network.requests[cur_request_id].outputs[self.out_blob]
        conf = res[0,0,:,2]
        rects = res[0, 0, :, 3:7]
        return conf, rects
detector = OpenVinoDetector(r'C:\Intel\computer_vision_sdk_2018.4.420\deployment_tools\model_optimizer\frozen_inference_graph.xml')
for i in range(0,10):
    frame = np.zeros((1, 3, 240, 320))
    conf,rects = detector.detect(frame)
I think problem in inference_engine library
void InferenceEnginePython::InferRequestWrap::infer_async() {
    InferenceEngine::ResponseDesc response;
    IE_CHECK_CALL(request_ptr->StartAsync(&response));
Because request_ptr is wrong.
If I move plugin initialization from class then application works.
Nikolaev__Viktor
Solved, It was problem with removing variables
del self.network
del self.plugin
谢__海蓉
Hello, Viktor
I want to know how I can import openvino in a python API, such as vsCode.
I can import openvino in command prompt, but it's not in Visual Studio Code.
thank you!
Shubha_R_Intel
Dear Victor and 谢, 海蓉:
You should find the below document quite useful,
https://docs.openvinotoolkit.org/latest/_inference_engine_ie_bridges_python_docs_api_overview.html
Thanks for using OpenVino !
Shubha
