Proposals to improve the examples
Hi.
I have started testing the sdk and I have verified that there is an example that does not match the version of cpp and python.
The cpp example of googlenet/Alexnet/SqueezeNet has less functionality than phyton example.
This is my proposal.
Insert in line 39 this code
// Labels family #define LABELS_FILE_NAME "../../../data/ilsvrc12/synset_words.txt"
After de code "fp16tofloat(resultData32, (unsigned char*)resultData16, numResults);", replace from line 213 to the end whit this code.
// load labels char category[100]; char *content = 0; char *labels[1000]; for(int i = 0; i < 1000; i++){ labels[i] = 0; } FILE *f = fopen(LABELS_FILE_NAME, "rb"); if(f != NULL){ fseek(f, 0, SEEK_END); size_t size = ftell(f); rewind(f); content = (char *)malloc(sizeof(char)*(size + 1)); if (content != NULL){ size_t read; read = fread(content, sizeof(char), size, f); fclose(f); if(size == read){ content[size] = 0; char * content2 = content; char *token; int pos = 0; while ((token = strsep(&content2, "\n")) != NULL && pos < 1000){ labels[pos++] = token + 10; } } } } int *results = NULL; int totalSizeResults = 10; int sizeResults = 0; results = (int *)malloc(sizeof(int) * totalSizeResults); if(results != NULL){ // we ignore all those that give a value 0 for (int index = 0; index < numResults; index++){ if (resultData32[index] > 0){ if(sizeResults == totalSizeResults){ totalSizeResults = sizeResults + 10; results = (int*) realloc (results, totalSizeResults * sizeof(int)); if(results == NULL){ --sizeResults; break; } } results[sizeResults++] = index; } } // sort descending int tmp = 0; for(int i=sizeResults - 1; i > 0; i--){ for(int j=i -1;j >= 0; j--){ if(resultData32[results[j]] < resultData32[results[j+1]]){ tmp=results[j+1]; results[j+1]=results[j]; results[j]=tmp; } } } // we show the categories for(int i=0, limiteI = sizeResults; i < limiteI; i++){ printf("Category %d - %s is: %f\n", results[i], 1000 > results[i]?labels[results[i]]:"", resultData32[results[i]]); } if(sizeResults > 0){ sprintf(category,"%d",results[0]); printf("The best candidate is: %s with a %f Probability\n", 1000 > results[0]?labels[results[0]]:category, resultData32[results[0]]); } } if(results != NULL){ free(results); } if(content != NULL){ free(content); } } } retCode = mvncDeallocateGraph(graphHandle); graphHandle = NULL; } free(graphFileBuf); retCode = mvncCloseDevice(deviceHandle); deviceHandle = NULL; }
