tensorflow example vgg16 MakeFile error
I would like to add vgg16 model in the tensorflow example, then I modified the Makefile, but the mvNCProfile -on parameter give me some error, like this:
[Error 13] Toolkit Error: Provided OutputNode/InputNode name does not exist or does not match with one contained in model file Provided: vgg16/Logits/Predictions/Reshape_1:0
Here is my MakeFile:
____MakeFile Begin____*
ifneq ($(findstring movidius, $(PYTHONPATH)), movidius)
export PYTHONPATH:=/opt/movidius/caffe/python:$(PYTHONPATH)
endif
NCCOMPILE = mvNCCompile
NCPROFILE = mvNCProfile
NCCHECK = mvNCCheck
.IGNORE: profile check compile
WEIGHTS_FILENAME = vgg_16_2016_08_28.tar.gz
GET_WEIGHTS = (wget http://download.tensorflow.org/models/${WEIGHTS_FILENAME} && tar zxf ${WEIGHTS_FILENAME} && rm ${WEIGHTS_FILENAME})
MODEL_FILENAME = output/vgg-16.meta
CONV_SCRIPT = ./vgg-16.py
INPUT_NODE_FLAG = -in=input
OUTPUT_NODE_FLAG = -on=vgg16/Logits/Predictions/Reshape_1
.PHONY: all
all: profile check compile
.PHONY: prereqs
prereqs:
(cd ../../data/ilsvrc12; make)
@sed -i 's/\r//' run.py
@chmod +x run.py
.PHONY: profile
profile: weights
${NCPROFILE} -s 12 ${MODEL_FILENAME} ${INPUT_NODE_FLAG} ${OUTPUT_NODE_FLAG}
.PHONY: browse_profile
browse_profile: weights
firefox output_report.html &
.PHONY: weights
weights:
@sed -i 's/\r//' ${CONV_SCRIPT}
@chmod +x ${CONV_SCRIPT}
test -f ${MODEL_FILENAME} || (${CONV_SCRIPT})
.PHONY: compile
compile: weights
test -f graph || ${NCCOMPILE} -s 12 ${MODEL_FILENAME} ${INPUT_NODE_FLAG} ${OUTPUT_NODE_FLAG}
.PHONY: check
check: weights
-${NCCHECK} -s 12 ${MODEL_FILENAME} ${INPUT_NODE_FLAG} ${OUTPUT_NODE_FLAG} -i ../../data/images/cat.jpg -id 917 -M 128 -S 2 -cs 0,1,2
.PHONY: run
run: compile
./run.py
.PHONY: run_py
run_py: compile
./run.py
.PHONY: help
help:
@echo "possible make targets: ";
@echo " make help - shows this message";
@echo " make all - makes the following: prototxt, profile, compile, check, cpp, run_py, run_cpp";
@echo " make weights - downloads the trained model";
@echo " make compile - runs SDK compiler tool to compile the NCS graph file for the network";
@echo " make check - runs SDK checker tool to verify an NCS graph file";
@echo " make profile - runs the SDK profiler tool to profile the network creating output_report.html";
@echo " make browse_profile - runs the SDK profiler tool and brings up report in browser.";
@echo " make run_py - runs the run.py python example program";
@echo " make clean - removes all created content"
clean:
rm -f output.gv
rm -f output.gv.svg
rm -f output_report.html
rm -f output_expected.npy
rm -f _.ckpt
rm -f output_result.npy
rm -f output_val.csv
rm -rf output
____MakeFile End_____
Please check my code,and point out all errors.Thank you!
