6574 Discussions
Pyinstaller issue with Openvino 2021.2.185
MCC
I was unable to use pyinstaller to build executable exe.
Below is my test python code.
from openvino.inference_engine import IECore
plugin = IECore()
model_xml = 'test.xml'
model_bin = 'test.bin'
net = plugin.read_network(model=model_xml, weights=model_bin)
exec_net = plugin.load_network(net, "CPU")
exec_net = plugin.load_network(net, "MYRIAD")
And I got the error below.
File "openvino\inference_engine\__init__.py", line 1, in <module>
File "ie_api.pyx", line 24, in init openvino.inference_engine.ie_api
ModuleNotFoundError: No module named 'openvino.inference_engine.constants'
[11956] Failed to execute script t2
And I used the below cmd to build exe.
python -m PyInstaller --add-data "C:\Program Files (x86)\Intel\openvino_2021.2.185\deployment_tools\inference_engine\bin\intel64\Release\plugins.xml;."^ --add-data "C:\Program Files (x86)\Intel\openvino_2021.2.185\deployment_tools\inference_engine\bin\intel64\Release\MKLDNNPlugin.dll;." --add-data "C:\Program Files (x86)\Intel\openvino_2021.2.185\deployment_tools\inference_engine\bin\intel64\Release\myriadPlugin.dll;."^ t2.py
Below is my environment:
OS: Both Windows 10
Python Version : 3.6.8
Pyinstaller Version : 4.1
Openvino Version : openvino_2021.2.185
Adli
Hi MCC,
Thank you for reaching out to us. If possible, could you share your reason for using pyinstaller to build an executable file?
Did you build the OpenVINO toolkit from the GitHub page
Adli
MCC
Hi Adli,
build the OpenVINO toolkit by the installer.
The original development envirnment is python ,  this one required to run on the different platforms.
Pyinstaller is a way to create executable file in the Windows platform without install python.
MCC
Adli
Hi MCC,
I am going to reproduce this case on my side. Are there any files that you would like to share that could help this investigation?
Adli
MCC
Hi Adli,
Unfortunately, I do not know which files are valuable.
MCC
Adli
Hi MCC,
Thank you for your prompt response. Currently, we are investigating this issue and will get back to you soon.
Adli
Adli
Hi MCC,
Thank you for your patience. It is not possible to convert an OpenVINO python demo/sample using Pyinstaller. This is due to the OpenVINO path/environment issue.
Adli
Munesh_Intel
Hi MCC,
PyInstaller is not officially supported by OpenVINO. However, some of our Community members have successfully created the executable file using PyInstaller. I share the following cases with you here:
https://community.intel.com/t5/Intel-Distribution-of-OpenVINO/Are-pyinstaller-and-openvino-incompatible/td-p/1168565
https://community.intel.com/t5/Intel-Distribution-of-OpenVINO/Exe-built-using-OpenVino-and-pyinstaller-does-not-work-with-R3/m-p/1188030
Please also refer to the following link for information on solving the ‘No module’ error.
https://stackoverflow.com/questions/58264381/python-importerror-openvino-by-script-and-by-shell
Munesh
Munesh_Intel
Hi MCC,
This thread will no longer be monitored since we have provided examples and references. If you need any additional information from Intel, please submit a new question.
Munesh
