Qt5.12.2 compiled OpenVINO failure
roc
Hi,guys
I met one issue that when used QT 5.12.2 compile OpenVINO2023 with error .In .pro file I set up environment :
LIBS += -L$$quote(C:\Program Files (x86)\Intel\openvino_2023.1\runtime\3rdparty\tbb\lib) \
                       -ltbb \ -ltbb12 \ -ltbbbind_2_5 \ -ltbbmalloc \ -ltbbmalloc_proxy
LIBS += -L$$quote(C:\Program Files (x86)\Intel\openvino_2023.1\runtime\lib\intel64\Release) \ -lopenvino \ -llibprotobuf-lite \ -lopenvino_pytorch_frontend \ -lopenvino_c \ -lopenvino_onnx_frontend
Then run code :
#include <openvino/openvino.hpp>
int main(int argc, char *argv[]) {
                std::cout << ov::get_openvino_version() << std::endl;
                return 0;
Compiled with QT :
C2127:ov::device::properties:illegal initialization of 'contexpr' entity with a non-constant expression,failure was because type  ov::device::Properties is not a literal type.
C2127 error located in properties.hpp line 746,749.
C2051:case expression  not constant.
C2127 error located in properties.hpp line 971,973.
Zulkifli_Intel
Hi roc,
Thank you for reaching out to Intel Customer Support.
We are checking this out. Do you have a CMAKE script? If yes please share it with us.
Sincerely,
Zul
Zulkifli_Intel
Hi roc,
Currently, we do not have any documentation on the Qt build for OpenVINO, and we cannot guarantee that it is going to work, but there is a discussion in StackOverflow that might interest you.
Sincerely,
Zulkifli
Zulkifli_Intel
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
