I'm trying to benchmark two SSD MobileNet v1 models (float and quantized ssd_mobilenet_v1_fpn_shared_box_predictor_640x640_coco14_sync_2018_07_03) from TF Object Detection API's zoo (the quantized model was obtained by adding the graph_rewriter block to pipeline config) and I experience several problems:
1. The float model was converted fine, but benchmark result is only 1.92 fps for 1 thread on CPU (I use Intel® Core™ i7-6700 CPU @ 3.40GHz × 4 in VirtualBox).
2. The quantized model fails to convert. I try to convert it with the following command:
/opt/intel/openvino/deployment_tools/model_optimizer/mo_tf.py \--input_model=/home/osboxes/trained_models/quantized_model/frozen_inference_graph.pb --tensorflow_use_custom_operations_config /opt/intel/openvino/deployment_tools/model_optimizer/extensions/front/tf/ssd_v2_support.json --tensorflow_object_detection_api_pipeline_config ~/trained_models/ssd_mobilenet_v1_fpn_input640_iv_voc+coco+ivcloud_3cl_2019_04_08_quantized/pipeline_from_SAMPLES_ssd_mobilenet_v1_fpn_640.config --output_dir ~/trained_models/converted/quantized/ --reverse_input_channels
But receive the message:
[ ERROR ] -------------------------------------------------
[ ERROR ] ----------------- INTERNAL ERROR ----------------
[ ERROR ] Unexpected exception happened.
[ ERROR ] Please contact Model Optimizer developers and forward the following information:
[ ERROR ] Exception occurred during running replacer "ObjectDetectionAPISSDPostprocessorReplacement (<class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPISSDPostprocessorReplacement'>)": FakeQuantWithMinMaxVars
[ ERROR ] Traceback (most recent call last):
File "/opt/intel/openvino_2019.1.144/deployment_tools/model_optimizer/mo/utils/class_registration.py", line 167, in apply_replacements
replacer.find_and_replace_pattern(graph)
File "/opt/intel/openvino_2019.1.144/deployment_tools/model_optimizer/mo/front/tf/replacement.py", line 89, in find_and_replace_pattern
self.replace_sub_graph(graph, match)
File "/opt/intel/openvino_2019.1.144/deployment_tools/model_optimizer/mo/front/common/replacement.py", line 131, in replace_sub_graph
new_sub_graph = self.generate_sub_graph(graph, match) # pylint: disable=assignment-from-no-return
File "/opt/intel/openvino_2019.1.144/deployment_tools/model_optimizer/extensions/front/tf/ObjectDetectionAPI.py", line 924, in generate_sub_graph
_relax_reshape_nodes(graph, pipeline_config)
File "/opt/intel/openvino_2019.1.144/deployment_tools/model_optimizer/extensions/front/tf/ObjectDetectionAPI.py", line 161, in _relax_reshape_nodes
assert (old_reshape_node.op == 'Reshape'), old_reshape_node.op
AssertionError: FakeQuantWithMinMaxVars
The above exception was the direct cause of the following exception:
File "/opt/intel/openvino_2019.1.144/deployment_tools/model_optimizer/mo/main.py", line 312, in main
return driver(argv)
File "/opt/intel/openvino_2019.1.144/deployment_tools/model_optimizer/mo/main.py", line 263, in driver
is_binary=not argv.input_model_is_text)
File "/opt/intel/openvino_2019.1.144/deployment_tools/model_optimizer/mo/pipeline/tf.py", line 127, in tf2nx
class_registration.apply_replacements(graph, class_registration.ClassType.FRONT_REPLACER)
File "/opt/intel/openvino_2019.1.144/deployment_tools/model_optimizer/mo/utils/class_registration.py", line 190, in apply_replacements
)) from err
Exception: Exception occurred during running replacer "ObjectDetectionAPISSDPostprocessorReplacement (<class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPISSDPostprocessorReplacement'>)": FakeQuantWithMinMaxVars
[ ERROR ] ---------------- END OF BUG REPORT --------------
Is there any way to work around this error and benchmark the quantized model? And also what could be the reason for float model to run so slow
Dear lipkin, semen,
It could be a model optimizer bug. Can you kindly attach your new pipeline.config for the quantized model here ?
Shubha
Thank you ,lipkin, semen. I will take a look.
Shubha
Dear lipkin, semen,
By "Quantized Model" do you mean Tensorflow Lite ? I'm reading about Quantized Models Tensorflow Documentation here. OpenVino does not support Tensorflow Lite today.
We definitely support INT8 quantization but not at the Model Optimizer stage. Instead we have a suite of calibration tools that handle this. Please read my detailed reply to dldt github issue 171 .
Hope it helps,
Shubha
