Raspbian Stretch Support
Any plans to put Raspbian Stretch/Python 3.5.3 support in, as this now the default Raspbian install (at the time of writing!)? At the moment ncapi/redist has Raspbian Jessie/Python 3.4 support.
As a workaround I installed using the pi_Jessie redistribution, then recursively copied the relevant files from /usr/local/lib/python3.4/dist-packages to /usr/local/lib/python3.5/dist-packages/. stream_infer.py (latest version) and ncs_camera.py then ran fine.
