Raspian 9: libopencv_ml.so.4.0 not found
Wios__Ed
I have followed the instructions listed here, all samples compiled well and ran without error. However, when I try the OpenCV samples, a simple
python3 -c "import cv2"
failed with the following error:
ImportError: libopencv_ml.so.4.0: cannot open shared object file: No such file or directory
ldd libopencv_ml.so.4.0 seems normal and have shown the correct paths. setupvars.sh was invoked and LD_LIBRARY_PATH and PYTHONPATH looks normal, too, at least the samples worked.
OS info:
PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
NAME="Raspbian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
I can see there is not much for "installation" as the whole VINO is already set and paths pointed by setupvars.sh. Therefore re-install wouldn't help I guess? Any idea what else could go wrong?
Thanks in advance.
//Ed
Wios__Ed
Ok, I've found a solution. Don't know why LD_LIBRARY_PATH was not used so I added them to /etc/ld.so.conf and now it no longer reported the error. However, I've ran into another serious issue with this OpenCV version on my Raspberry Pi 3b+ :  FATAL ERROR: This OpenCV build doesn't support current CPU/HW configuration.
_Mai_
any updates on this problem?
I've been having it on ubuntu 18.04 since I installed  openvino_2020.4.287
it only happens in pycharm, it works fine in the terminal
it ruined every environment I have even if I install a separate version of opencv there
