Reset NSC2 Each time network is loaded with Python API
Nowlan__Andrew
I'm trying to reset the MYRIDA NSC2 each time a network is loaded. That is, i'm trying to set  MYRIAD_FORCE_RESET = YES using the Python API.  The docs say it must be set using the set_config() method, but i have been ubale to do this after reading the docs.  Would you be able to provide a python example of how this should be done? Or point to an example?
Thanks in advance.
https://docs.openvinotoolkit.org/latest/_docs_IE_DG_supported_plugins_MYRIAD.html#MYRIAD_DEVICE_ALLOC ;
Iffa_Intel
Greetings,
You can use netiface, https://github.com/raphdg/netifaces
import netifaces,
#This function returns returns True when an IP address is associated to a given interface(connected to internet)
def is_interface_up(interface):
                   addr = netifaces.ifaddresses(interface)
                   return netifaces.AF_INET in addr
if addr ==1 : do_something
else: do_something()
You can check this out too:  https://medium.com/@f.i.rabby/python-network-manager-tutorial-c504cdb8fc76
Hope my answer helps!
Sincerely,
Iffa
Nowlan__Andrew
I think you have misunderstood me. I mean each i want to enable the force reset of all booted devices when new ExecutableNetwork is created with the python API as metioned here .
Iffa_Intel
try to run python sample &  omit the KEY_ prefix
This part is specifying key values as raw strings (that is, when using Python API)                This part is Omit Key_prefix
./decemberpei/openvino-ncs2-python-samples/blob/master/async_api_multi-processes.py KEY_VPU_MYRIAD_FORCE_RESET=YES
Sincerely,
Iffa
Iffa_Intel
Im closing this case. If there are any other inquiries please help to create a new thread.
Thanks & have a great day ahead!.
Sincerely,
Iffa
