- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
I'm working on pervasive device that had support for the caffe framework and I'm attempting to use resnet-10 from opencv to do face detection (https://github.com/opencv/opencv/tree/master/samples/dnn/face_detector). The graph file compiles fine, and the first pass even executes fine and then the device hangs. The following is the trace I'm getting from the device
[INFO] Get Tensor Descriptor Structures
[INFO] create input and output Fifos
I: [ 0] ncFifoCreate:2126 Init fifo
I: [ 0] ncFifoAllocate:2321 Creating fifo
[INFO] return input and output Fifos
[INFO] Sending Image to NCS device]
D: [ 0] ncFifoWriteElem:2592 No layout conversion is needed 0
D: [ 0] convertDataTypeAndLayout:170 src data type 1 dst data type 0
D: [ 0] convertDataTypeAndLayout:172 SRC: w 300 h 300 c 3 w_s 12 h_s 3600 c_s 4
D: [ 0] convertDataTypeAndLayout:174 DST: w 300 h 300 c 3 w_s 6 h_s 1800 c_s 2
D: [ 0] ncFifoWriteElem:2617 write count 0 num_elements 2 userparam 0x75a86418
[INFO Sendiing to NCS Queue]
I: [ 0] ncGraphQueueInference:3048 trigger start
I: [ 0] ncGraphQueueInference:3145 trigger end
D: [ 0] ncFifoReadElem:2686 No layout conversion is needed 0
D: [ 0] convertDataTypeAndLayout:170 src data type 0 dst data type 1
D: [ 0] convertDataTypeAndLayout:172 SRC: w 7 h 201 c 1 w_s 2 h_s 14 c_s 2
D: [ 0] convertDataTypeAndLayout:174 DST: w 7 h 201 c 1 w_s 4 h_s 28 c_s 4
D: [ 0] ncFifoReadElem:2714 num_elements 2 userparam 0x75a86558 output length 5628
[INFO] Image prdictions returned from NCS
1
1
D: [ 0] ncFifoWriteElem:2617 write count 1 num_elements 2 userparam 0x75a86418
E: [ 0] dispatcherEventReceive:200 dispatcherEventReceive() Read failed -1
I notice in the SDK readme that this model had not been tested but Resnet-50 had, so I tried that Model with the same results. The trace from that run can be found below
D: [ 0] convertDataTypeAndLayout:172 SRC: w 224 h 224 c 3 w_s 12 h_s 2688 c_s 4
D: [ 0] convertDataTypeAndLayout:174 DST: w 224 h 224 c 3 w_s 6 h_s 1344 c_s 2
D: [ 0] ncFifoWriteElem:2617 write count 0 num_elements 2 userparam 0x75ac4468
D: [ 0] ncFifoReadElem:2686 No layout conversion is needed 1
D: [ 0] convertDataTypeAndLayout:172 SRC: w 1 h 1 c 1000 w_s 2000 h_s 2000 c_s 2
D: [ 0] convertDataTypeAndLayout:174 DST: w 1 h 1 c 1000 w_s 4000 h_s 4000 c_s 4
D: [ 0] ncFifoReadElem:2714 num_elements 2 userparam 0x75ac45a8 output length 4000
0
0
D: [ 0] ncFifoWriteElem:2617 write count 1 num_elements 2 userparam 0x75ac4468
The Device works fine for other SSD models I have tried so I don't think I have a hardware problem. The frustrating thing on this problem is it works the first pass fine. Any help would be greatly appreciated.
コピーされたリンク
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
@sggriset Thanks for reporting this issue. I've also seen these hangs with the same networks and they usually happen during fifo.read_elem(). Can you provide your python code for testing and issue reproduction? Thanks.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Thank you for your quick response. The following code is set up for resnet-10 SSD from opencv. If you adjust the dimensions you can test resnet-50 also. Assuming you have the graph files so here you go
# import necessary libs
import usb.core # from pyusb
import usb.util # from pyusb
import mvnc.mvncapi as mvnc
from threading import Thread
import numpy as np
import time
import cv2
import os
VID = 0x03e7
PID = 0x2150
dim_prep = (300, 300)
graph_path = os.path.relpath("graphs/facecvgraph")
out_fifo = 'faceout'
in_fifo = 'facein'
graph_name = 'facegraph'
class WebcamVideoStream:
def __init__(self, src = 0):
# initialize the video camera stream and read the frist frame
# from the stream
self.stream = cv2.VideoCapture(src)
# camera returns a tuple grabbed = boolean value whether the frame was read
# frame = the video frame itself
(self.grabbed, self.frame) = self.stream.read()
# initialize the variable used to indicate if the thread should
# be stopped
self.stopped = False
def start(self):
# start the thread to read frames from the video stream
Thread(target = self.update, args=()).start()
return self
def update(self):
# keep looping infinitely until the tread is stopped
while True:
# if the thread indicator variable is set, stop the thread
if self.stopped:
return
# otherwise read the next frame from the stream
def read(self):
# return the frame most recently read
return self.frame
def stop(self):
# indicate that the thread should be stopped
self.stopped = True
def preprocess_image(input_image, dim):
# preprocess the image
preprocessed = cv2.resize(input_image, dim)
preprocessed = preprocessed - 127.5
preprocessed = preprocessed * 0.007843
preprocessed = preprocessed.astype(np.float32)
# return the image to the callling function
return preprocessed
# Load graph files and return graph object
def load_graph(device, Graphpath, graph_name):
# Initalize a graph
print(Graphpath)
print("[INFO] loading the graph file into NCS memory")
with open(Graphpath, mode='rb') as f:
graph_buffer = f.read()
print("[INFO] initialize graph object ")
# Initalize a graph object
graph = mvnc.Graph(graph_name)
# Allocate the graph to the device
print("[INFO] allocating the graph to the NCS")
graph.allocate(device, graph_buffer)
# return graph object
return graph
def get_tensors(graph, device, input_name, output_name):
print("[INFO] Get Tensor Descriptor Structures")
input_descriptors = graph.get_option(mvnc.GraphOption.RO_INPUT_TENSOR_DESCRIPTORS)
output_descriptors = graph.get_option(mvnc.GraphOption.RO_OUTPUT_TENSOR_DESCRIPTORS)
print("[INFO] create input and output Fifos")
input_fifo = mvnc.Fifo(input_name, mvnc.FifoType.HOST_WO)
output_fifo = mvnc.Fifo(output_name, mvnc.FifoType.HOST_RO)
input_fifo.allocate(device, input_descriptors[0], 2)
output_fifo.allocate(device, output_descriptors[0], 2)
print("[INFO] return input and output Fifos")
return input_fifo, output_fifo
def predict(image, graph, input_fifo, output_fifo):
# send the image to the NCS and run a forward-pass to grab the
# netowrk predictions
print("[INFO] Sending Image to NCS device]")
input_fifo.write_elem(image, None)
print("[INFO Sendiing to NCS Queue]")
graph.queue_inference(input_fifo, output_fifo)
(output, _ ) = output_fifo.read_elem()
print("[INFO] Image predictions returned from NCS")
# grab the number of valid object predictions from the output
num_valid_boxes = int(output[0])
predictions = []
for box_index in range(num_valid_boxes):
# calculate the base index into our array so we can extract
# bound box information
base_index = 7 + box_index * 7
# boxes with non-finite(inf, nan, etc) numbers must be
# ignored
if(not np.isfinite(output[base_index]) or
not np.isfinite(output[base_index + 1]) or
not np.isfinite(output[base_index + 2]) or
not np.isfinite(output[base_index + 3]) or
not np.isfinite(output[base_index + 4]) or
not np.isfinite(output[base_index + 5]) or
not np.isfinite(output[base_index + 6])):
continue
# extract the image width and height and clip the boxes to the
# image size in case network returns boxes outside of the image
# boundaries
(h, w) = image.shape[:2]
x1 = max(0, int(output[base_index + 3] * w))
y1 = max(0, int(output[base_index + 4] * h))
x2 = min(w, int(output[base_index + 5] * w))
y2 = min(h, int(output[base_index + 6] * h))
# grab the prediction class label, confidence,
# and bounding box (x, y) - coordinates
pred_class = int(output[base_index + 1])
pred_conf = output[base_index + 2]
pred_boxpts = ((x1, y1), (x2, y2))
# create prediction tuple and append the prediction to the
# predictions list
prediction = (pred_class, pred_conf, pred_boxpts)
predictions.append(prediction)
print(len(predictions))
# return the list of predictions to the calling function
return predictions
def main():
mob_device = usb.core.find(idVendor=VID, idProduct=PID)
if not mob_device:
print ("[INFO] Movidius Device Not Found")
exit(1)
print ("[INFO] Found Movidius Device")
# set the logging level for the Movidius device
mvnc.global_set_option(mvnc.GlobalOption.RW_LOG_LEVEL, 0)
devices = mvnc.enumerate_devices()
if(len(devices) < 1):
print("[INFO] Error - no Movidius devices detected")
exit(1)
# get the first NCS device
dev = mvnc.Device(devices[0])
try:
dev.open()
except:
print("[INFO] Error - Could not open NCS device.")
exit(1)
# load graph file
my_graph = load_graph(dev, graph_path, graph_name)
# set up Fifos
inputfifo, outputfifo = get_tensors(my_graph, dev, in_fifo, out_fifo)
vs = WebcamVideoStream(src = 0).start()
# let camera warm up
time.sleep(2.0)
while True:
frame = vs.read()
frame = preprocess_image(frame, dim_prep)
key = key = cv2.waitKey(1) & 0xFF
if key == 'q':
break
predictions = predict(frame, my_graph, inputfifo, outputfifo)
cv2.destroyAllWindows()
vs.stop()
input_fifo.destroy()
output_fifo.destroy()
dev.destroy()
exit(0)
if __name__ == '__main__':
main()
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Tome_at_Intel
Any progress on reproduction of problem? Do you have what you need to reproduce the problem? Or do you need to supply you the graph files and model?
Let me know again thank you for your help
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
@sggriset If you could also provide the model file with the prototxt file, it would be helpful to me. Thanks again.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Tome_at_Intel
You can find the caffe model file at the following url
https://github.com/opencv/opencv_3rdparty/tree/dnn_samples_face_detector_20170830
You can find the prototxt file (deploy.prototxt) file at the following url https://github.com/opencv/opencv/tree/master/samples/dnn/face_detector
Let me know what else I can do for you. Thank you for your help and enjoy your weekend.
Steve
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello, I'm interested too, this model runs fine on OpenCV.
Thanks!
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Any update on this issue would be greatly appreciated
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
I'm interested too. Any update on this issue would be greatly appreciated
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Still working on this issue. Hang tight guys.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
No updates to report as of right now. Still looking into the root cause.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello,@Tome_at_Intel, any update on this issue?
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
@xzongbao We apologize that this issue is affecting our users, however at the moment, we don't have any updates that we can share yet. We greatly appreciate your patience while we work on resolving this issue.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
@xzongbao @sggriset Please try running your models with the latest NCSDK v 2.08 and let me know if your issue is resolved. Thanks.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Tome_at_Intel
Sorry for the slow response I had to rebuild my systems to test NCSDK v 2.08 release. It worked fine but it does require you to rebuild the graph file under NCSDK v 2.08. But thank you to Intel team for your fix
Steve
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
@Tome_at_Intel
I have upgraded to NCSDK v2.08. It‘s ok to run the demo ResNet-18 of the ncappzoo. But for my ResNet-34 model, a compilation error has occurred. The compilation is OK before upgrading.
Network Input tensors ['data#162']
Network Output tensors ['prob#323']
File "/usr/local/bin/mvNCCompile", line 206, in
create_graph(args.network, args.image, args.inputnode, args.outputnode, args.outfile, args.nshaves, args.inputsize, args.weights, args.explicit_concat, args.ma2480, args.scheduler, args.new_parser, args.cpp, args)
File "/usr/local/bin/mvNCCompile", line 185, in create_graph
load_ret = load_network(args, parser, myriad_config)
File "/usr/local/bin/ncsdk/Controllers/Scheduler.py", line 130, in load_network
net, graphFile, finalLayers = serializeNewFmt(parsedLayers, arguments, myriad_conf, input_data)
File "/usr/local/bin/ncsdk/Controllers/Parsers/Phases.py", line 508, in serializeNewFmt
adp.transform(parsedLayers) # TODO: DFS Transform?
File "/usr/local/bin/ncsdk/Controllers/Adaptor.py", line 200, in transform
self.net.attach(NetworkStageEmulator(l))
File "/usr/local/bin/ncsdk/Controllers/Adaptor.py", line 325, in init
self.specific_fields()
File "/usr/local/bin/ncsdk/Controllers/Adaptor.py", line 333, in specific_fields
self.definition.adapt_fields(self, _or)
File "/usr/local/bin/ncsdk/Models/StageDefinitions/Relu_Op.py", line 50, in adapt_fields
emulator.dataBUF = BufferEmulator(i.resolve())
File "/usr/local/bin/ncsdk/Controllers/Tensor.py", line 200, in resolve
rt = ResolvedTensor(self)
File "/usr/local/bin/ncsdk/Controllers/Tensor.py", line 310, in init
self.__data = np.zeros(tensor.shape)
MemoryError
Makefile:52: recipe for target 'compile' failed
make: *** [compile] Error 1
