6594 Discussions
Run AVX instructions on a non-supported AVX CPU
Gouveia__César
What happens if I try to run a pre-compiled AVX dll (with a set of AVX operations) on a CPU that does not support AVX? I suppose it will give some sort of illegal instruction error and the code will stop. Does OpenVINO have any counter-measures to face this? OpenVINO functions/operations certainly make use of AVX, does it rollback to some baseline functions when the CPU where the code is being executed does not have AVX support?
César.
Sahira_Intel
Hi César,
If you're installing OpenVINO on a CPU that does not support AVX instructions, the installation will fail. As per the system requirements, a 6th to 10th generation Intel Core, Intel Xeon processor, Pentium® processor N4200/5, N3350/5, N3450/5 with Intel® HD Graphics is required. There aren't any workarounds to this that are verified by Intel.
I hope this information is helpful. Please let me know if you have any further questions.
Sahira
Sahira_Intel
Hi César,
Sahira
Gouveia__César
Thanks for the quick response Sahira,
Just another question, what happens if I try to run a pre-compiled AVX dll (with a set of AVX operations) on another system/solution which uses OpenVINO backend but with a CPU that does not support AVX, eventually it will crash because of invalid instructions right?
César.
