6605 Discussions
hi I am using NCS2 and running demos of Ncappzoo and I am getting error "Please initiate the Intel OpenVINO environment by going to the installation directory for openvino and running the setupvars.sh file in the bin folder.
tmazh
hi I am using NCS2 and running demos of Ncappzoo and I am getting error "Please initiate the Intel OpenVINO environment by going to the installation directory for openvino and running the setupvars.sh file in the bin folder. Makefile:80: recipe for target"
please provide the steps to take and code to solve the problem thanks
JAVIERJOSE_A_Intel
Hi tmazh,
Thanks for reaching out.  You can set the environment variables running the following command:
source <OpenVINO Installation Dir>/bin/setupvars.sh
The installation and setup guides teach you how to set your environment variables depending on your Operative System.
You can find the guides at the following link:
https://software.intel.com/en-us/openvino-toolkit/documentation/get-started
Javier A.
Intel Customer Support Technician
A Contingent Worker at Intel
tmazh
JAVIERJOSE_A_Intel
Hi tmazh,
Thank you for your response. In order to help you, could you please answer some question that we have for you:
Which version of the OpenVINO™ Toolkit are you using?
What Operative System do you have?
Did you clone the master branch of the GitHub repository?
Javier A.
tmazh
using 2019 R3.1 latest version on linux and i did clone the github repository by doing the command git clone https://github.com/movidius/ncappzoo.git
JAVIERJOSE_A_Intel
Hi tmazh,
Thank you for the information that you provided to us. Can you specify the Linux distribution that you are using?
If you have any additional details about your setup that may help us to replicate the issue, please feel free to share it with us.
Javier A.
JAVIERJOSE_A_Intel
Hi tmazh,
I hope you are doing well.
I am contacting you to give a follow up on this thread. Could you please answer my previous message to assist you?
Javier A.
tmazh
hi,
i have to use cat vs dogs data set from kaggle link is below
https://www.kaggle.com/xtianvillaruz/cats-and-dogs-with-cnn-tensorflow
using neural stick need some guidance.
JAVIERJOSE_A_Intel
Hi tmazh,
The Intel® Neural Compute Stick 2 and the OpenVINO™ toolkit are only used for deployment. You will need to train a model in Tensorflow with the dataset. Once you have a trained network, you can use the model optimizer to convert your .pb file to the IR format for inference on the Intel® NCS 2.
You can find more information about the model optimizer on the following link:
https://docs.openvinotoolkit.org/latest/_docs_MO_DG_Deep_Learning_Model_Optimizer_DevGuide.html
If you have any other questions, please feel free to ask.
Javier A.
JAVIERJOSE_A_Intel
Hi tmazh,
I am contacting you to give a follow up on this thread. Could you please tell me if you were able to use the Intel® Neural Compute Stick 2 successfully?
If there is anything else we can help you with, do not hesitate to contact us again.
Javier A.
tmazh
thanks will get back to you once have any questions.
