Running OpenVino in a Docker container
Kunjavskij__Igor
Hi everyone,
I am currently running into the issue that if I start a Docker container on a Raspberry Pi this way
docker run --privileged -v /dev:/dev -it --rm <docker image>
and run an application inside that should utilize the Neural Compute Stick, I get the following error:
E: [ncAPI] [    160605] [python3] ncDeviceOpen:844      Failed connection to device (1.1.3-ma2450) with error 7
Traceback (most recent call last):
  File "run.py", line 35, in <module>
    exec_net = plugin.load(network=net, num_requests=2)
  File "ie_api.pyx", line 551, in openvino.inference_engine.ie_api.IEPlugin.load
  File "ie_api.pyx", line 561, in openvino.inference_engine.ie_api.IEPlugin.load
If it try to run the application inside the Docker container as root, I get the following error:
  File "run.py", line 7, in <module>
    from openvino.inference_engine import IENetwork, IEPlugin
ImportError: No module named 'openvino'
Did anyone else run into similar problems or would someone have an idea what I could do to fix this? Any help would be appreciated!
Thanks and kind regards,
Igor
Kenneth_C_Intel
Yeah it looks like you are just missing the command to set up the environment.
inside of the openvino installation directory (normally /opt/intel/openvino) there is a bin folder that should contain setupvars.sh
You will need to source that file before running any application using openvino.
Kenneth_C_Intel
Kunjavskij__Igor
Thank you very much, that solved my problem!
Shubha_R_Intel
Dear Kunjavskij, Igor,
Glad it solved your problem and thanks for reporting back to the OpenVino community !
Shubha
