- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
I'm using raspberrypi 3b+ with Myriad X NCS2 to run object_detection_demo_ssd_async.py.
Before run this, I have finished all the Tutorial and run successfully.
But I'm facing problems.
System information
1、Linux raspberrypi 4.14.71-v7+
2、raspberrypi 3b+
Problem Description
When I run
python3.5 /home/pi/cwz/object_detection_demo_ssd_async.py -i cam -m /home/pi/cwz/ssd_v2/frozen_inference_graph.xml --labels /home/pi/cwz/ssd_v2/frozen_inference_graph.mapping -d MYRIAD
pi@raspberrypi:~ $ python3.5 /home/pi/cwz/object_detection_demo_ssd_async.py -i cam -m /home/pi/cwz/ssd_v2/frozen_inference_graph.xml --labels /home/pi/cwz/ssd_v2/frozen_inference_graph.mapping -d MYRIAD
[ INFO ] Initializing plugin for MYRIAD device...
[ INFO ] Reading IR...
[ INFO ] Loading IR to the plugin...
File "/home/pi/cwz/object_detection_demo_ssd_async.py", line 185, in <module>
sys.exit(main() or 0)
File "/home/pi/cwz/object_detection_demo_ssd_async.py", line 80, in main
exec_net = plugin.load(network=net, num_requests=2)
File "ie_api.pyx", line 395, in openvino.inference_engine.ie_api.IEPlugin.load
File "ie_api.pyx", line 406, in openvino.inference_engine.ie_api.IEPlugin.load
RuntimeError: [VPU] Unsupported network precision : FP32
I don't know what the problem is and I can't find the solution after google.
Thanks!
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Dear Wade,
Please see the below document. You cannot use FP32 on Myriad. You must use --data_type FP16 in the model optimizer command which generates IR.
https://docs.openvinotoolkit.org/latest/_docs_IE_DG_supported_plugins_Supported_Devices.html
Shubha
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Dear Wade,
Shubha
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Dear Shubha R. (Intel),
Thanks for your reply! After I add --data_type FP16 to generates IR , it works well.
But another problem occurs,
my model is ssd_mobilenet_v1_coco, my script to generate IR
python mo_tf.py --input_model ssd_mobilenet_v1_coco_2018_01_28\frozen_inference_graph.pb --tensorflow_use_custom_operations_config extensions/front/tf/ssd_support.json --tensorflow_object_detection_api_pipeline_config ssd_mobilenet_v1_coco_2018_01_28\pipeline.config --reverse_input_channels --data_type FP16
and my input is camera stream
when I run
python3.5 /home/pi/cwz/object_detection_demo_ssd_async.py -i cam -m /home/pi/cwz/ssd_v1_coco/frozen_inference_graph.xml --labels /home/pi/cwz/ssd_v1_coco/frozen_inference_graph.mapping -d MYRIAD
the detection results are confused, it shows lots of frames at the same time. (I have screenshot and post.)
I don't know which part that I have done wrong.
Thanks!
Wade
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I change a model, ssd_mobilenet_v2_coco,and it works well.
my script to generate IR,
python mo_tf.py --input_model ssd_mobilenet_v2_coco_2018_03_29\frozen_inference_graph.pb --tensorflow_use_custom_operations_config extensions/front/tf/ssd_v2_support.json --tensorflow_object_detection_api_pipeline_config ssd_mobilenet_v2_coco_2018_03_29\pipeline.config --data_type FP16
my script to run object_detection_demo_ssd_async.py,
python3.5 /home/pi/cwz/object_detection_demo_ssd_async.py -i cam -m /home/pi/cwz/ssd_v2_coco/frozen_inference_graph.xml --labels /home/pi/cwz/ssd_v2_coco/frozen_inference_graph.mapping -d MYRIAD
In my expectations. the detection frames would show the detection classes,
in object_detection_demo_ssd_async.py, line 148
det_label = labels_map[class_id] if labels_map else str(class_id)
if I give it a mapping document in my script, then 'det_label' would be given the corresponding classes according to the 'class_id'.
But it only shows 'map' or 'mapping', which confuses me a lot. (screenshot and post already)
I think it might be some parameters I miss when I generate IR, and I try to add --output=detection_boxes,detection_scores,detection_classes,num_detections to my script,
but it didn't work either.
Wade
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Dear Wade,
First, I hope you are using the latest version of OpenVino 2019 R1. It seems that you're using the --output switch to mo_tf.py incorrectly. The below document describes it in more detail, but you should pass layer names to the --output switch.
https://docs.openvinotoolkit.org/latest/_docs_MO_DG_prepare_model_convert_model_Cutting_Model.html
So unless detection_boxes,detection_scores,detection_classes,num_detections are layer names, I don't see how your mo_tf.py worked.
But in fact you did successfully generate IR using a correct mo_tf.py command.
Can you post your frozen_inference_graph.mapping here ?
Also instead of - cam, how does it work with mp4 video ? You can select one to test from here:
https://github.com/intel-iot-devkit/sample-videos
Please post your results here.
Thanks for using OpenVino !
Shubha
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
hello @wade can you please help me,
how to add data_type FP16 in the model optimizer command which generates IR?
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Dear K J, Manu
As Wade showed above, the mo_tf.py command should be similar to this:
Shubha
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
thank you @Shubha R. (Intel) it worked
but ma'am is there a way where we can get the labels file from the model optimizer while creating bin and xml .........
because, when i run the object_detection_demo_ssd_async.py i didnt get the label of the detection
...query image is attached below
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
