RuntimeError in make examples
I had a RuntimeError in make examples.
RuntimeError: module compiled against API version 0xb but this version of numpy is 0xa
Please give me any advice to solve the problem.
My environment:
Raspberry PI3, Raspbian stretch with desktop
Movidius NC SDK version: 1.10.01.00
$ uname -a
Linux raspberrypi 4.9.59-v7+ #1047 SMP Sun Oct 29 12:19:23 GMT 2017 armv7l GNU/Linux
My operation:
I followed the Movidius quick start guide below.
mkdir -p ~/workspace cd ~/workspace git clone https://github.com/movidius/ncsdk.git cd ~/workspace/ncsdk make install
After make install, there are no error.
I opened a new terminal window and checked environment variable, PYTHONPATH=:/opt/movidius/caffe/python.
then,
cd ~/workspace/ncsdk make examples Continue installing OpenCV (y/n) ? n
Message:
I got the following message;
making compile
mvNCCompile -w bvlc_googlenet.caffemodel -s 12 deploy.prototxt
mvNCCompile v02.00, Copyright @ Movidius Ltd 2016
File "/usr/local/bin/mvNCCompile", line 118, in
create_graph(args.network, args.inputnode, args.outputnode, args.outfile, args.nshaves, args.inputsize, args.weights)
File "/usr/local/bin/mvNCCompile", line 100, in create_graph
from Controllers.CaffeParser import parse_caffe
File "/usr/local/bin/ncsdk/Controllers/CaffeParser.py", line 29, in
import caffe
File "/opt/movidius/caffe/python/caffe/init.py", line 1, in
from .pycaffe import Net, SGDSolver, NesterovSolver, AdaGradSolver, RMSPropSolver, AdaDeltaSolver, AdamSolver, NCCL, Timer
File "/opt/movidius/caffe/python/caffe/pycaffe.py", line 15, in
import caffe.io
File "/opt/movidius/caffe/python/caffe/io.py", line 2, in
import skimage.io
File "/usr/local/lib/python3.5/dist-packages/skimage/io/init.py", line 7, in
from .manage_plugins import *
File "/usr/local/lib/python3.5/dist-packages/skimage/io/manage_plugins.py", line 28, in
from .collection import imread_collection_wrapper
File "/usr/local/lib/python3.5/dist-packages/skimage/io/collection.py", line 14, in
from ..external.tifffile import TiffFile
File "/usr/local/lib/python3.5/dist-packages/skimage/external/tifffile/init.py", line 1, in
from .tifffile import imsave, imread, imshow, TiffFile, TiffWriter, TiffSequence
File "/usr/local/lib/python3.5/dist-packages/skimage/external/tifffile/tifffile.py", line 293, in
from . import _tifffile
Makefile:80: target 'compile' recipe failed
make[4]: *** [compile] Error 1
Have the exact same issue with mvNCCompile v02.00. I installed opencv separately (version 3.3) is this a problem?
Upgrade numpy to 1.13 issue is fixed.
Hi, manojgeorge
I checked and upgraded numpy version as below.
pip3 show numpy ... Version : 1.12.1 ... sudo pip3 install --upgrade numpy ... pip3 show numpy ... Version : 1.13.3 ...
I could go to next step in "make examples".
Thank you very much.
