Status Error during Inference
Hi to everyone!!
I made a network with a very simple structure:
input = Input(shape=(1, 28, 3), name='input') x = Conv2D(filters=1, kernel_size=(1,1), use_bias=False, strides=(1,1), padding='valid', name='conv2d')(input) x = Flatten()(x) x = initial_model(x)
where intial_model is a feed forward fully connected network with input 28 (coming from the previous part) and 5 as output.
I was able to export the .graph file, but when I make inference I get the following error:
" E: [ 0] dispatcherEventReceive:246 dispatcherEventReceive() Read failed -2
E: [ 0] eventReader:267 Failed to receive event, the device may have reset
Traceback (most recent call last):
File "main.py", line 143, in
app.start()
File "main.py", line 122, in start
output, user_obj = output_fifo.read_elem()
File "/usr/local/lib/python3.5/dist-packages/mvnc/mvncapi.py", line 412, in read_elem
raise Exception(Status(status))
Exception: Status.ERROR"
To debug any type of error I'm simply simulating a possible input with the following code:
input_final = np.ones((1,1,28,3)).astype(np.float32) graph.queue_inference_with_fifo_elem(input_fifo, output_fifo, input_final, 'obj user') output, user_obj = output_fifo.read_elem()
Do you have any idea what's going on?
Thank you in advance for your help!
N.B: if I leave the code running without output_fifo.read_elem() method, it runs for 3/4 seconds and then report a similar error, but on line 767.
Hi @EscVM
Thank you for reaching out, could you share your code for me to reproduce? Also, which device and SDK are you using?
Jesus
