[TF] NANs appear after concat
직원
1,997 조회수
Hello!
I have mobilenet's like graph where the end operation is concatV2.
All layers before concat give results without NANs but the final concat layers give the NANs:
https://drive.google.com/open?id=1WydK5qRbfTTK8dUDBN5qfftP72P2sQWi
mvNCCheck graph_optim.pb -in=image -on TfPoseEstimator/feat_concat
Result: (28, 28, 864)
1) 677375 nan
2) 461212 nan
3) 461240 nan
4) 461239 nan
5) 461238 nan
Expected: (1, 28, 28, 864)
1) 676897 32.22853
2) 653518 32.084774
3) 653723 32.062202
4) 653946 31.285995
5) 654040 29.77494
node { name: "TfPoseEstimator/feat_concat" op: "ConcatV2" input: "TfPoseEstimator/Conv2d_3_pool" input: "TfPoseEstimator/MobilenetV1/Conv2d_7_pointwise/Relu" input: "TfPoseEstimator/MobilenetV1/Conv2d_11_pointwise/Relu" input: "TfPoseEstimator/feat_concat/axis" attr { key: "N" value { i: 3 } } attr { key: "T" value { type: DT_FLOAT } } attr { key: "Tidx" value { type: DT_INT32 } } }
I've checked all inputs
and they give OK results (as an example for TfPoseEstimator/Conv2d_3_pool):
mvNCCheck /home/fast/openpose/tf-pose-estimation/chk2/graph_optim.pb -in=image -on TfPoseEstimator/Conv2d_3_pool
Result: (28, 28, 96)
1) 72639 15.2
2) 72653 14.516
3) 72659 13.28
4) 73311 12.97
5) 73695 12.97
Expected: (1, 28, 28, 96)
1) 72639 15.215018
2) 72653 14.516435
3) 72659 13.285161
4) 74559 12.965318
5) 73695 12.963984
(inputs also pass every test)
0 포인트
8 응답
직원
1,715 조회수
deleted
0 포인트
직원
1,715 조회수
If I add proxy (for example max pool with kernel=1) after 'TfPoseEstimator/MobilenetV1/Conv2d_7_pointwise/Relu:0' and replace original node in concat with this proxy, it becomes OK!
conc_in_1 = graph.get_tensor_by_name('TfPoseEstimator/Conv2d_3_pool:0') conc_in_2 = graph.get_tensor_by_name('TfPoseEstimator/MobilenetV1/Conv2d_7_pointwise/Relu:0') conc_in_3 = graph.get_tensor_by_name('TfPoseEstimator/MobilenetV1/Conv2d_11_pointwise/Relu:0')
proxy= tf.nn.max_pool(conc_in_2,ksize=[1, 1, 1, 1],strides=[1, 1, 1, 1], padding='SAME', name='proxy')
test_conc1 = tf.concat([conc_in_1, proxy, conc_in_3], 3, name='test_conc')
Result: (28, 28, 864) 1) 676897 32.22 2) 653723 32.16 3) 653946 31.42 4) 654040 29.88 5) 653920 29.81 Expected: (1, 28, 28, 864) 1) 676897 32.2097 2) 653723 32.097595 3) 653518 32.080677 4) 653946 31.31227 5) 654040 29.789398
So obviously it's very insulting bug that can be fixed!
0 포인트
직원
1,715 조회수
@jokilokis Thanks for pointing this out. The bug has to do with the last layer being a concat layer. We're working on a release candidate for this issue at the moment.
0 포인트
직원
1,715 조회수
wow, thanks @Tome_at_Intel, does it mean I need to add fake layer to be the last layer?
0 포인트
직원
1,715 조회수
I want to know that when can this bug be fixed?
0 포인트
직원
1,715 조회수
@songyoff lets try my approach with fake pooling after some input node to concat.
TfPoseEstimator/feat_concat/Proxy 0.7 651.8 1.985
as I can see pooling s very fast operation on stick but it helps to avoid some compiler optimizations that lead to bugs
proto representation as an example what I mean:
node { name: "TfPoseEstimator/MobilenetV1/Conv2d_7_pointwise/Relu/Proxy" op: "MaxPool" input: "TfPoseEstimator/MobilenetV1/Conv2d_7_pointwise/Relu" attr { key: "T" value { type: DT_FLOAT } } attr { key: "data_format" value { s: "NHWC" } } attr { key: "ksize" value { list { i: 1 i: 1 i: 1 i: 1 } } } attr { key: "padding" value { s: "SAME" } } attr { key: "strides" value { list { i: 1 i: 1 i: 1 i: 1 } } } } node { name: "TfPoseEstimator/feat_concat" op: "ConcatV2" input: "TfPoseEstimator/Conv2d_3_pool" input: "TfPoseEstimator/MobilenetV1/Conv2d_7_pointwise/Relu/Proxy" input: "TfPoseEstimator/MobilenetV1/Conv2d_11_pointwise/Relu" input: "TfPoseEstimator/feat_concat/axis" attr { key: "N" value { i: 3 } } attr { key: "T" value { type: DT_FLOAT } } attr { key: "Tidx" value { type: DT_INT32 } } }
Hope it helps while the fix is coming
0 포인트
직원
1,715 조회수
@jokilokis thanks a lot, it's a good trick before the bug is fixed
0 포인트
직원
1,715 조회수
@jokilokis , I have met the same problem with you. Adding a proxy can get normal output of 'feat_concat', but the latter layer still got nan. Have you successfully run the pose network on the stick?
0 포인트
응답
