to follow install and problem solved instruction , but still got the error -1001 message.
test environment
- Ubuntu: 18.04 LTS
- CPU: i5-1145GRE
- GPU: Intel® Iris® Xe Graphics
- Intel OpenVINO toolkit: 2021.2
- OpenCL runtime library: 20.43.18277
issue has been solved when Linux kernel version 5.8.0. here is installation information for reference
Version |
Ubuntu O/S |
20.04 LTS w/ Linux Kernel version 5.8.0 |
Intel OpenVINO Toolkit |
2021.2 |
OpenCL Driver |
manual install 20.43.18277 。 |
Hi Kevinlin,
Thank you for reaching out to us. If possible, could you share additional information regarding:
- The command/program that you run when you get the error.
- Full log error in text/snapshot if available.
Adli
to use pedestrian tracker demo in model FP16 :test should loading GPU failed
command line:
person-detection-0101.xml
person-reidentification-0256.xml
error screen shoot
Hi Kevinlin,
If possible, could you run the 'demo_squeezenet_download_convert_run.bat' infer with GPU? The demo is located in the '<openvino_dir>\deployment_tools\demo' directory. Please share the outcome here.
Adli
Version |
Ubuntu O/S |
2021.2 |
OpenCL Driver |
Hi Kevinlin,
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Adli
![](/skins/images/4399995709D76C02984DDB9A1DB96C28/responsive_peak/images/icon_anonymous_message.png)
