The worlds first AI edge ncs2 cameras - OpenVINO - Raspberry Pi - Up board
Peniak__Martin
Hi guys,
UPDATE (18/01/19): Video demonstration: https://vimeo.com/311111323
I thought I’d share my latest innovations with you.
Two AI edge camera prototypes, one using RPi and it’s more compact:
https://www.timeless.ninja/blog/the-world-s-first-ai-edge-camera-powered-by-two-intel-myriad-x-vpus
and the other one based on Up board, larger but more powerful:
https://www.timeless.ninja/blog/the-world-s-first-ai-edge-camera-powered-by-up-squared-and-three-intel-myriad-x-vpus
Let me know if you have any questions. I’ll be also at the Intel devcon in Munich this January so if you’re around let me know.
Martin Peniak, PhD
Head of Innovation | Cortexica
Kang__June
Awesome immediate application.
Is there linear (or almost linear) computational advantage of parallelizing NCS2?
Peniak__Martin
Thanks for your comment, I do appreciate it! Yes there is a near linear scaling based on my observation.
RTasa
I have SO many questions based on your parts list. The Up2 has CPU choices which one do you have? You mentioned using the UP AI Core X Deep Neural Networks Hardware accelerator. Did you? Was that in the box? What graphs have you tested? Are they all FP 16? Are you only using the 2 NCS2 sticks for this application? What is the video input size? Are you evaluating HD, SD or 1/2 SD video frames in your graphs you are using?   Have you run Yolo on it? Does the Myriad X give you more power than 2 NCS2 sticks? Which version of the AI Core X did you use.
Peniak__Martin
The Up board one was based on this same hardware as in here: https://up-shop.org/home/251-up-squared-ai-edge-ppe-monitoring-powered-by-cortexica.html
I've tested mobilenet-ssd on this particular setup; VPUs and GPUs need FP16 so that's what I used. CPU needs FP32 so one model is FP32.
For the UP based AI Edge camera I use 2 NCS and one Myriad X on mini-PCIe...I believe this is covered in the blog.
The input size of mobilenet-ssd is 300x300 in this case. I have another model of 600x600 but was not any better.
Cheers
RTasa
That should give you about 12 TOPS of processing power, assuming each Movidius device delivers its max of 4TOPS. I love the casing.
Boaz__Jabulon
do u know what is the comand to run the Inference using the Raspberry pi camera?
-i /dev/video0 or -i /dev/video1 or - i cam and manu other comands don't work with the Pi Camera. -i /dev/video0 or -i /dev/video1 only work with USB web cameras
Boaz__Jabulon
Boaz, Jabulon
Tue, 01/08/2019 - 10:42
What is the comand to run the Inference using the Raspberry pi camera?
-i /dev/video0 or -i /dev/video1 or - i cam and manu other comands don't work with the Pi Camera. -i /dev/video0 or -i /dev/video1 only work with USB web cameras.
E. g. That works with the USB web cam on the pi but does not work with the Raspberry pi camera:
./armv7l/Release/object_detection_demo_ssd_async -i /dev/video0 -m frozen_inference_graph.xml -d MYRIAD
hamze60
Can you tell about performance, how many FPS? I saw some other discussion on internet by @PINTO that NCS2's performance is poor, and, for now, the reported benchmarks by Movidius official page is a big question  for me.
Peniak__Martin
Depending on the model but mobilenet-ssd was like 10-12FPS on some models and on the super light face detection model from the intel repo is was nearly 20FPS...That being said, I have developed this (https://up-shop.org/home/251-up-squared-ai-edge-ppe-monitoring-powered-by-cortexica.html), which has MyriadX (just like NCS2) and the same model runs at 40FPS so yeah I am not impressed either but I could not say I am disappointed either :)
Here you see both cameras in action: https://vimeo.com/311111323
Peniak__Martin
Hi guys,
I thought I would let you know that I've also made a quick video demonstration of both cameras.
Check this out if you are interested: https://vimeo.com/311111323
Martin Peniak, PhD
Reinberger__Thomas
Hi Martin,
which model did you use to perform the body parts detection as shown in your latest video? Maybe we can catch up during the Intel AI Devcon tomorrow.
Cheers
Thomas
Kulecz__Walter
Boaz, Jabulon wrote:
Boaz, Jabulon
There is a kernel module to provide a video for Linux driver for the Pi so it can be accessed as /dev/videoN
// edit
sudo nano /etc/modules
// add:
bcm2835-v4l2
If I remember correctly the module was part of the stock Raspbian Stretch image.
Norman__Michael
I've had working prototype using the pi camera using an NCS1 since last year - and based on experience I strongly recommend going with a MIPI CSI2 source over USB for the pi, if you can find one that fits your needs.
The PI's USB limitations mean your NCS sticks and the camera will have to share bandwidth, along with the network, and storage (if you're driving an SSD and booting off the USB).
If you're interested in performance,and have the budget, consider an up squared, add wifi via the m.2, and get a Myriad X mPCIe module.
Peniak__Martin
Thanks! This is based on two NCS2, PoE enabled and works nice and smooth...no probs with the performance!
I did do the up square version which has its use cases too but it’s much larger and considering the CortexiCAM based on Pi3B+ is really fast I prefer this one. Anyway here is the second design for the reference:
https://www.martinpeniak.com/blog/the-world-s-first-ai-edge-camera-powered-by-up-squared-and-three-intel-myriad-x-vpus
