There is no file CMakeLists.txt
fikri
Im used VS 2019, cmake 3.20, python 3.6. get this error: ###############|| Generate VS solution for Inference Engine demos using cmake ||############### Waiting for 0 seconds, press a key to continue ... Creating Visual Studio 16 2019 x64 files in C:\Users\user\Documents\Intel\OpenVINO\inference_engine_demos_build... -- Selecting Windows SDK version 10.0.19041.0 to target Windows 10.0.19043. -- The C compiler identification is MSVC 19.29.30040.0 -- The CXX compiler identification is MSVC 19.29.30040.0 -- Detecting C compiler ABI info CMake Error at C:/Program Files/CMake/share/cmake-3.20/Modules/CMakeDetermineCompilerABI.cmake:49 (try_compile): Failed to open C:/Users/user/Documents/Intel/OpenVINO/inference_engine_demos_build/CMakeFiles/CMakeTmp/CMakeLists.txt Permission denied Call Stack (most recent call first): C:/Program Files/CMake/share/cmake-3.20/Modules/CMakeTestCCompiler.cmake:26 (CMAKE_DETERMINE_COMPILER_ABI) CMakeLists.txt:16 (project) -- Detecting C compiler ABI info - failed -- Check for working C compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.29.30037/bin/Hostx64/x64/cl.exe CMake Error at C:/Program Files/CMake/share/cmake-3.20/Modules/CMakeTestCCompiler.cmake:53 (try_compile): Failed to open C:/Users/user/Documents/Intel/OpenVINO/inference_engine_demos_build/CMakeFiles/CMakeTmp/CMakeLists.txt Permission denied Call Stack (most recent call first): CMakeLists.txt:16 (project) -- Check for working C compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.29.30037/bin/Hostx64/x64/cl.exe - broken CMake Error at C:/Program Files/CMake/share/cmake-3.20/Modules/CMakeTestCCompiler.cmake:66 (message): The C compiler "C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.29.30037/bin/Hostx64/x64/cl.exe" is not able to compile a simple test program. It fails with the following output: CMake will not be able to correctly generate this project. Call Stack (most recent call first): CMakeLists.txt:16 (project) -- Configuring incomplete, errors occurred! See also "C:/Users/user/Documents/Intel/OpenVINO/inference_engine_demos_build/CMakeFiles/CMakeOutput.log". See also "C:/Users/user/Documents/Intel/OpenVINO/inference_engine_demos_build/CMakeFiles/CMakeError.log". Error
David_G_Intel
Hello fikri
Thank you for posting on the Intel️® communities. We will move your question to the correct sub forum, the team in charge will get back to you soon.
David G
Wan_Intel
Hi Fikri,
I noticed that you have posted a similar question in OpenVINO™ community at the following thread:
https://community.intel.com/t5/Intel-Distribution-of-OpenVINO/CMAKE-Error/m-p/1301727
Are you okay to continue the conversation at the OpenVINO™ community thread above?
Wan
Wan_Intel
Hi Fikri,
Thank you for your question.
I'd like to notify you that we will continue our conversation in the OpenVINO™ community at the following thread:
If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
Wan
