Hi, I got an error when trying to compile a simple MNIST caffe model for the Movidius stick. I have changed the prototxt file for the Movidius stick.
File "/usr/local/bin/mvNCCompile", line 118, in
create_graph(args.network, args.inputnode, args.outputnode, args.outfile, args.nshaves, args.inputsize, args.weights)
File "/usr/local/bin/mvNCCompile", line 101, in create_graph
net = parse_caffe(args, myriad_config)
File "/usr/local/bin/ncsdk/Controllers/CaffeParser.py", line 328, in parse_caffe
input_bottom = net.bottom_names[inputNodeName][0]
IndexError: list index out of range
====== prototxt file ===========
input: "data"
input_shape {
dim: 1
dim: 1
dim: 28
dim: 28
layer {
type: "Convolution"
bottom: "data"
top: "conv1"
param {
lr_mult: 1
param {
lr_mult: 2
convolution_param {
num_output: 20
kernel_size: 5
stride: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "Pooling"
bottom: "conv1"
top: "pool1"
pooling_param {
pool: MAX
kernel_size: 2
stride: 2
layer {
type: "Convolution"
bottom: "pool1"
top: "conv2"
param {
lr_mult: 1
param {
lr_mult: 2
convolution_param {
num_output: 50
kernel_size: 5
stride: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "Pooling"
bottom: "conv2"
top: "pool2"
pooling_param {
pool: MAX
kernel_size: 2
stride: 2
layer {
type: "InnerProduct"
bottom: "pool2"
top: "ip1"
param {
lr_mult: 1
param {
lr_mult: 2
inner_product_param {
num_output: 500
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "ip1"
top: "ip1"
layer {
bottom: "ip1"
top: "ip2"
param {
lr_mult: 1
param {
lr_mult: 2
num_output: 10
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
========= Compilation ==========
mvNCCompile mymodel.prototxt -w mymodel.caffemodel -s 12 -in input -on ip2 -is 28 28 -o my_net.graph
I have modified the prototxt file for the Movidius stick.
Sahad
Hi, I was able to compile by changing the input node in compilation command to "conv1" instead of "input" .
mvNCCompile ./mymodel.prototxt -w ./mymodel.caffemodel -s 12 -in conv1 -on ip2 -is 28 28 -o ./my_net.graph
Unfortunately, it gives inconsistent results. I think the input node in compilation should be "input". But, there seems to have a bug when giving "input" as the input node.
Sorry, my bad..
,works fine.
I ran a VGG 19 layer pre-trained model to classify between 1000 different image classes of Imagenet, with an inference time of almost 0.98 seconds..
![](/skins/images/44D6FBC13D1AFC21DF3F0C7813903D74/responsive_peak/images/icon_anonymous_message.png)
