6574 Discussions
Unable to run a program on NCS2, however same program runs when device is selected as CPU
SDhim3
Created a custom model using tensorflow
used mo.py to convert my model to .bin and .xml
import cv2 as cv
# Load the model.
net = cv.dnn.readNet('face-detection-adas-0001.xml',
           'face-detection-adas-0001.bin')
# Specify target device.
net.setPreferableTarget(cv.dnn.DNN_TARGET_MYRIAD)
# Read an image.
frame = cv.imread('face.jpg')
if frame is None:
  raise Exception('Image not found!')
# Prepare input blob and perform an inference.
blob = cv.dnn.blobFromImage(frame, size=(672, 384), ddepth=cv.CV_8U)
net.setInput(blob)
out = net.forward()
# Draw detected faces on the frame.
for detection in out.reshape(-1, 7):
  confidence = float(detection[2])
  xmin = int(detection[3] * frame.shape[1])
  ymin = int(detection[4] * frame.shape[0])
  xmax = int(detection[5] * frame.shape[1])
  ymax = int(detection[6] * frame.shape[0])
  if confidence > 0.5:
    cv.rectangle(frame, (xmin, ymin), (xmax, ymax), color=(0, 255, 0))
# Save the frame to an image file.
cv.imwrite('out.png', frame)
When Device is MYRIAD, program throws error at out = net.forward() , step
Error:
AssertionFailed: weights->desc().totalDimSize() >=kernelSizeX * kernelSizeY * (input->desc().dim(Dim::C)/groupSize) * output->desc().dim(Dim ::C) in function initPlugin
but when same program being run on CPU, it works fine.
OS: Ubuntu 16.04 LTS
please suggest, what needs to be done.
JesusE_Intel
Hi SDhim3,
I have a couple of questions regarding your setup:
  • What OpenVINO toolkit version are you using?
  • What is the size of your model?
  • What topology is your custom trained model based on?
  • Could you share the Tensorflow model and converted IR model?
    • How did you convert the model to IR format? Please provide model optimizer command.
You can share the files through a private message by clicking on my user name and clicking the "message" button.
Jesus
