6597 Discussions
''UnpopulatedTensor" error for running an inference model trained with SSD on Movidius stick
I have an inference model trained with SSD Caffe.
I put my caffemodel and prototxt files into examples/caffe/GoogleNet folder and change file names to bvlc_googlenet.caffemodel and deploy.prototxt.
So that I don't need to update at different places.
Then inside GoogleNet folder, I run
make run
But I have compile failed errors as follow.
making prereqs (cd ../../data/ilsvrc12; make) make[1]: Entering directory '/home/itc/Softwares/Projects/Movidius/ncsdk/examples/data/ilsvrc12' make[1]: Leaving directory '/home/itc/Softwares/Projects/Movidius/ncsdk/examples/data/ilsvrc12' making prototxt Prototxt file already exists making caffemodel caffemodel file already exists making compile mvNCCompile -w bvlc_googlenet.caffemodel -s 12 deploy.prototxt /usr/local/bin/ncsdk/Controllers/Parsers/TensorFlowParser/Convolution.py:46: SyntaxWarning: assertion is always true, perhaps remove parentheses? assert(False, "Layer type not supported by Convolution: " + obj.type) /usr/local/bin/ncsdk/Controllers/Parsers/Phases.py:322: SyntaxWarning: assertion is always true, perhaps remove parentheses? assert(len(pred) == 1, "Slice not supported to have >1 predecessors") mvNCCompile v02.00, Copyright @ Intel Corporation 2017 <caffe._caffe.BlobVec object at 0x7fe53b11e800> <caffe._caffe.BlobVec object at 0x7fe53b11e9e0> <caffe._caffe.BlobVec object at 0x7fe53b11ebc0> <caffe._caffe.BlobVec object at 0x7fe53b11eda0> <caffe._caffe.BlobVec object at 0x7fe53b1225d0> <caffe._caffe.BlobVec object at 0x7fe53b1227b0> <caffe._caffe.BlobVec object at 0x7fe53b122990> <caffe._caffe.BlobVec object at 0x7fe53b122b70> <caffe._caffe.BlobVec object at 0x7fe53b122d50> <caffe._caffe.BlobVec object at 0x7fe53b122f30> <caffe._caffe.BlobVec object at 0x7fe53b114210> <caffe._caffe.BlobVec object at 0x7fe53b114490> <caffe._caffe.BlobVec object at 0x7fe53b1146c0> <caffe._caffe.BlobVec object at 0x7fe53b114940> <caffe._caffe.BlobVec object at 0x7fe53b114bc0> <caffe._caffe.BlobVec object at 0x7fe53b114e40> <caffe._caffe.BlobVec object at 0x7fe53b112120> <caffe._caffe.BlobVec object at 0x7fe53b112350> <caffe._caffe.BlobVec object at 0x7fe53b112580> <caffe._caffe.BlobVec object at 0x7fe53b112760> <caffe._caffe.BlobVec object at 0x7fe53b1129e0> <caffe._caffe.BlobVec object at 0x7fe53b112c10> <caffe._caffe.BlobVec object at 0x7fe53b112e90> <caffe._caffe.BlobVec object at 0x7fe53b115170> <caffe._caffe.BlobVec object at 0x7fe53b1153a0> Traceback (most recent call last): File "/usr/local/bin/mvNCCompile", line 206, in <module> create_graph(args.network, args.image, args.inputnode, args.outputnode, args.outfile, args.nshaves, args.inputsize, args.weights, args.explicit_concat, args.ma2480, args.scheduler, args.new_parser, args.cpp, args) File "/usr/local/bin/mvNCCompile", line 185, in create_graph load_ret = load_network(args, parser, myriad_config) File "/usr/local/bin/ncsdk/Controllers/Scheduler.py", line 102, in load_network parsedLayers = convertBiasLayersToEltwise(parsedLayers) File "/usr/local/bin/ncsdk/Controllers/Parsers/Phases.py", line 857, in convertBiasLayersToEltwise converted.setInputTensors(first_input) File "/usr/local/bin/ncsdk/Controllers/Parsers/Parser/Layer.py", line 112, in setInputTensors self.inputTensors = tuple(t) TypeError: 'UnpopulatedTensor' object is not iterable Makefile:80: recipe for target 'compile' failed make: *** [compile] Error 1
What could be wrong?
@coi can you send me your files? I will try to reproduce the problem.
@Oliver_at_Intel Hello, thank you.
Please download prototxt file here and
caffemodel is here
@Oliver_at_Intel Here is labelmap file. Thank you.
Sorry labelmap file is here.
@Oliver_at_Intel , hi Oliver! any chance to test my files for the issue. Thanks
@coi Hi coi, I was able to download and test your model. I was able to reproduce the same issue and I'm still investigating the root cause of the problem. Thanks for your patience. I'll let you know as soon as I find something.
@coi There seems to be a bug with the NCSDK while parsing your model. Normally the NCSDK takes the Bias layer and changes it to a Eltwise Add, but during this process, an error occurs when setting the input tensor. There isn't a workaround that I can provide at the moment, but I will let you know as soon as we find a solution for this issue. Thanks.
@Tome_at_Intel Thank you Tome, for your great support. Since I am using the stick for one of my applications, your help will be very grateful for me.
@Tome_at_Intel Dear Tome, can find a solution for my case?
