6613 Discussions
compile tensorflow inception v3 retrain graph
I have trained a tensorflow inception v3 model following the below steps, can anyone suggest how to convert it to a graph for ncsdk?
1.
retrain the inception model.
ref: https://github.com/googlecodelabs/tensorflow-for-poets-2
python scripts/retrain.py --output_graph=tf_files/retrained_graph.pb --output_labels=tf_files/retrained_labels.txt --image_dir=tf_files/images/
2.
remove nodes so it can be loaded with cv2.dnn.readNetFromTensorflow
ref: http://answers.opencv.org/question/175699/readnetfromtensorflow-fails-on-retrained-nn/
python ~/tensorflow/tensorflow/python/tools/optimize_for_inference.py \ --input graph.pb \ --output opt_graph.pb \ --frozen_graph True \ --input_names DecodeJpeg/contents \ --output_names final_result ~/tensorflow/bazel-bin/tensorflow/tools/graph_transforms/transform_graph \ --in_graph=opt_graph.pb \ --out_graph=final_graph.pb \ --inputs=Mul \ --outputs=final_result \ --transforms="remove_nodes(op=PlaceholderWithDefault) strip_unused_nodes(type=float, shape=\"1,299,299,3\") sort_by_execution_order"
